I have a 2021 Sierra Denali and mine just started doing this.  I had a 2020 Denali and the wireless charger sucked.  It definitely was improved for the 2021 year. It's been working perfect for the last six months and only in the last month or so maybe two months have I noticed that it will only charge for about five seconds and then it stops. It doesn't matter if it has a case on it or not and I'm using an iPhone 13 Pro Max
  • 1 year later...
I have a 2022 GMC Sierra 3500 and I'm having the same problem.  I have an iPhone 15.  It was working fine up to about 1 week ago and now it starts to charge when placed down and then after about 5-10 seconds it stops........
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 523 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
