I was curious how they test it. Wasnt sure if they just toss their own phone on it or not.  But yea, ill report back tomorrow when i pick the truck up.
Awesome, thanks
Had the same issue with my iPhone 11 pro max in my 19 Sierra. Wife's iPhone XR does the same thing. It also does it in her 2018 Traverse. I put IOS 14 beta on my iPhone and no longer have the issue in either my truck or wife's Traverse. Wife's iPhone XR on IOS 13 still has the issue. Must be an Apple issue. IOS 14 has some issues so  don't use it if you need a stable phone.
Jay
Edited by Jay P
2 hours ago, eppieguy said:
Totally agree.
I was thinking an update issue as well.  Hopefully sorted out in the next update.
Same problem here. iPhone 11 Pro. I’m betting it’s a software issue. Have the same problem in the house charging it wirelessly. It’s not the hardware in the truck. I’m hoping ios14 fixes it.
So im wondering if i should take my truck in tomorrow or cancel the appointment. The new new BCM is in but is there a point to replacing it if its an apple software issue.
I’d tell the dealer about this and see what they think (may be worth a shot in the dark)
Last week it would fail to charge 9/10 times. Between replacing the pad and an iphone update (13.6), fails to charge 3/11 times.  Just stopped by the dealership to ask them about software and the guy tried his samsung. It worked 5/5 times.  He is going to confirm with the tech tomorrow to see what they think as they use a box almost like a voltage meter that detects if its working or not.
I’m downloading the update now and I’ll check it tomorrow.
Did the update and tried it. It charged 4/10 times.
No change in mine. Doesn’t charge more than it charges. My son can put his iPhone XS on it and it works fine. He is running Same updated software. Same case no issues. I think it’s a hardware problem with the iPhone 11 Pro.
No change in mine. Doesn’t charge more than it charges. My son can put his iPhone XS on it and it works fine. He is running Sam updated software. Same case no issues. I think it’s a hardware problem with the iPhone 11 Pro.
What iOS is your son running?
Same as mine. 13.6. He did the update as well. I tried his before the update and his charged fine. The funny thing is mine phone worked all the time when I first got it back in October. Then something happened along the way. It’s weird. I have to try my wife’s iPhone tonight when o get home. She has an 11pro she just got last week.
I have not had this issue with my 11 pro max/truck. Just did a 200 mile road trip today and no issues. Phone was 25% when I started, and 100% when I got home. Hope it stays that way!
Got ya, I’m curious how your wife’s phone will be
Could it have something to do with the optimizing setting? I’m going to turn mine off and find out.
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
