Searched, but nothing.
2019 LTZ. Suddenly the radio knobs have a problem. Volume knob will turn up the radio but not down, same with the other knob, turn to right and works, left does not. Steering wheel controls works fine
Anyone else? It'll be going to dealer, just curious
Sent from my SM-N975U using Tapatalk
Probably just glitching like all the other computers eventually do on this truck.
I’d just pull a battery cable for 30 minutes or so and see if that fixes it. If so, that saves you a trip to the dealer because all they’re gonna do is “reset” the radio.
I'll give it a whirl. I thought maybe a turn it off, back on might do it, but nope. I'll try battery
I’ve had so many electrical quirks/problems that I just let the truck sit overnight and see if it goes away. Specifically with hard shifts from park to reverse and then drive and also when the front park sensors glitch and become inoperative.
I’m done wasting my time with trips to the dealer just for them to say “we couldn’t replicate the problem so we just reset the module” [emoji849]
Reset made it worse actually [emoji1787], now both knobs will do random sporadic things, volume down and change channel and move the screen...so weird.
Dealer is ordering a new display, should be here in a few days
    • I like things to be more nailed down. For instance. People ask why my father left a multi million dollar business in NJ in the seventies and started over in Texas. The answer is simple, payola, threats and quality of life. He didn’t like the game. And he didn’t want his kids to be wrapped up in that mess. That’s nailed down no guessing.
    • So any kind of deviation is not permitted. Even if it manages to touch on Oils Chain intervals only if, it addresses your latest threat. Boring.😴
    • The tailgate of pickups is not designed to be water tight. There are seal kits for them but I doubt they work effectively. But, I've not tried them. I always have hard folding tonneau covers and the BakFlip brand has been my favorite. And, for the most part, the bed stays dry. I would invest in some bins that can be closed to better protect sensitive stuff.
    • A properly installed tonneau will keep out 95% of the water.  As others have said, the only way to be completely dry is to either get a topper or an SUV.   I've run virtually all the trifolds and hard rolling that are out there.  My thoughts:   1.)  The leak points of any cover will be the front corners, and around the tailgate.   They will also leak if the rails are not installed properly.  If you take a electric/cordless ratchet and snug down the clamps, you run the risk of overtightening which causes the rails to sag.  When the rails sag it creates a gap between the rail and the bed cap and this lets water in.   2.)  Different manufacturers use different methods to try and seal the front.  The "driest" setup is probably the Leer HF650M, which uses double seals all the way around and doesn't require a foam seal across the front edge of the bed.  The Realtruck trifold covers (Bak, Undercover, Gator, etc...) all use a foam seal across the front, and drain tubes.   3.)  Realtruck has standardized the way that the cover attaches to the rail.  With the exception of the Extang Endure ALX, all other Realtruck covers use a plastic clamp which slides into a channel, hooks onto the edge of the rail, and tightens down. The "Realtruck Advantage" covers sold by GM dealers as an OEM accessory still use the "bolt through the panel" installation method.  Problem with these is over time, water gets past the rubber seal, into the panel, and once they become waterlogged they begin to delaminate (and weigh a ton.)   4.)  Unless you are using GM Rewards points, buy your cover separately.  Realtruck offers a 5 year warranty on BAK, Undercover and Extang covers.  Gators get either a 2 or 3 year warranty.  If you have an issue, they are much easier to deal with.  If you have an issue with an OEM GM cover, you have to go through the service department and GM Warranty processes to get it taken care of.   Recommendations based on my experience:   Hard folding:   1.)  Undercover Ultra/Armor Flex (identical except Ultra has carpet on the underside and a smooth finish.  Armor has no carpet but has a Line-X coating on the outside.) 2.)  Leer HF650M.  Has 4 panels instead of 3.  Double seals to keep the water out.  Downside is only a 3 year warranty and warranty only honored if you purchase from a Leer dealer.  If you have your dealer install it or buy off Amazon they won't warranty it. 3.)  Bak MX4.  They sell a ton of them.  A good cover for the money when you can find one on sale.  About to be redesigned to include a spring to ease opening and closing. (Supposed to be released 7/26.  Bak MX4 EZ-Lift)   Hard rolling:   Bak Revolver X4S or X4TS (has t-slot rails.)  Personal favorite and the one I use on my truck.  Easy to roll up one handed.  Doesn't block the rear window.  Only costs you about 6" of the bed when open as opposed to a retractable canister which eats up about a foot of bedspace.  Downside is it's either all the way open or all the way closed.   Good luck with you search.
    • Does any of this change if the seller dropped the price to $22.5k?  Mechanic is supposed to verify the transmission concern but they have not got back to me yet.  Even if a transmission needed to be purchased, I'm looking at <$30k which puts me right back to where I started.   In the meantime, I test drove 2 trucks locally back-to-back, one Denali and one SLE, the SLE was noisy, jerky, and did not inspire confidence, while the Denali was over $30k but just sold the other day.  If $32k buys you a Denali with 100k miles and this truck can be had for $32k with a brand new transmission, with GM parts warranty, does that skew things?   FWIW, all the trucks I drove locally had a much worse service history - emissions work, valve body work, one even had the whole transmission replaced with lower mileage than the one in TX.  I'm guessing those were "short trip" vehicles, as they only racked up around 100k miles in 6 years - a lot less than 164k miles in just under 6 years.
