Did you consider whipple or other brands? I am looking right now for my 6.2 and the PCM unlocking is where I am unsure. Did you get a second PCM or do the PCM exchange and lose your original core?
Mind sharing the cost breakdown of the PC vs HP tuner etc?
Currently
in the process of installing the procharger. Any tricks or ideas on how to get the crank bolt
off? I’ve tried 650lb impact driver but only 8 gallon compressor? I’m thinking that might be to small?
Tried the breaker bar with a pipe extension also. That bolt is actually welded on there ...
On 10/4/2020 at 8:31 PM, CamGTP said:
Stronger impact with more air behind it.
I couldn’t get a hold Of either. But I talked to an auto body shop they said to heat the bolt up for about ten minutes then try cracking it. Basically I just took a propane torch to the center of the bolt and held it for 10 minutes. The bolt cracked easy after that. I let the bolt cool down before fully unscrewing it after. Looked as though there was some locktight on the bolt head and a little heat managed to loosen that up a bit.
Another question... what’s the clearance on the main bracket and the alternator pulley? When I fully tighten the main bracket bolts the pulley and bracket are touching... I removed the top long spacer and bolt and it seemed to open up the gap between the two but only about a 16th of an inch... I measured the spacer and it appears the top one is a 16th of an inch off of the what the numbers are in the directions. Just curious if the main bracket and alternator pulley are really supposed to be that close or if there if more of a gap you think?
Found the issue. New spacers being sent from procharger. That about sums up how this installation has been lol
You exchange your original pcm. Ship it to HP tuners and they send you back an unlocked one. They send you everything you need to do this. Make sure you have a windows os. I used parralels on my MacBook so I can boot the windows os anytime no need to restart the computer or buy a separate laptop.
cost is the same as on the hp tuners website for the exchange service on chevy pcms it’s included into the price for the procharger kit.
12 hours ago, Ryguy said:
Y’all should be getting major discounts for being test dummies for this ******  ?
Honestly. Procharger f***ed up on my kit forsure lol what I thought would be about a week install turning into 3-4 weeks now
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 546 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
