you bet. many ways to do it. let us know what your thinking
  • 1 month later...
Sure you can. I got my gmt900 07 crew ltz about 4 1/2 years ago with 99k. I promptly replaced the head unit with a Kenwood touchscreen system. I got a secondary controller that allows me to still have OnStar and my steering wheel controls, but now I also have Apple CarPlay, Serious XM, HD radio, Navigation, etc. . At the same time I added back-up and dash cameras (also Kenwood).
I got the whole package from Crutchfield in VA with ready made (soldered) wiring harnesses, a dash install kit and custom install directions for my truck. It was all about $1000, and then I installed myself.
Now I’m not a pro, (as in do mobile electronics for a living) but I have worked on all my own stuff since I was a kid. It took me 4-5 hours and a call to Crutchfield but they were Johnnie on the spot with their customer/technical service and I have been happy ever since. If anyone is interested I can take some photos tomorrow, I tried a minute ago but it’s too dark and they are not coming out very well. I realize this may sound like an advertisement for Crutchfield but it’s not. I couldn’t afford them as a kid but as a faithful current customer, they are a great choice in this space.
If you want to go with a dash cam and not upgrade the head unit, you could still remove the drivers A pillar cover and drop the front drivers portion of the headliner, in order to run keyed power from the fuse box and then mount the camera like mine. Most of them come with removable storage so you really don’t need it attached to the head unit. In this case (if you ever had a problem) remove the data card from the camera and view or download to a computer via usb with a card reader.
Edited by Ross Reynolds
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 511 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
