Hmm...I’m not sure how to link to another post. There’s a reference manual sticky in the 2020 HD forum that I tried to give a link to. I use Tapatalk on my phone and if you’re not that might be the link issue.
For the 2020 Chevrolet 3500 HD with the duramax diesel, the rear differential capacity is 6.3 pints.  FYI, for this same vehicle, the capacity for the front differential for trucks with 4 wheel drive is 3.8 pints.  This capacity information was found on the AMSOIL web site.   When I change the fluid in my truck's real limited slip differential, I also plan to add some limited slip friction modifier.
This is from the reference sticky I was trying to link you to.
Rear Axle 12.0"
• Axle Lubricant:75w90 Synthetic Lubricant, 10-4016 / 88900401
• Capacity: 3.17 Quarts
What limited slip did you put in your truck?
6 hours ago, rblanch said:
Does anyone know or know where to get the fluid capacity for 3500 srw. Rear end fluid. The owners Manuel just says see dealer
Is it a brand new truck?  You can look it up here, otherwise you would need to get with the dealer with your VIN to make sure.
I called a local Chevrolet dealer and spoke to the parts counter employee.  He looked up the truck (2020 Chevy 3500 HD with diesel, etc.)  and said his documentation does not list the rear axle or front axle fluid capacity.  His documentation did list certain other fluid capacities such as engine oil, transmission, etc.  Don't know why his info didn't list capacity for axles.  Regardless, he advised when he changes his own gear oil in his rear axle (on an older vehicle), he adds sufficient fluid that he can put the last digit of his little finger in the rear axle lubricant fill hole and if he can touch the new fluid, he considers it done in terms of the fill level.  That's the rule of thumb I've heard service personnel say, also.  When I get around to changing my rear differential gear oil on my 2020 3500HD diesel with limited slip, I plan to buy 4 quarts of the appropriate viscosity gear oil and, after draining the "old" fluid and reinstalling the drain plug to add my new fluid until I can touch the new fluid as noted above.  Then, I will add 4 ounces of limited slip additive that I'll buy either at the Chevy dealer or I may buy the AMSOIL limited slip product.  Using this technique, worst case is I have some extra gear oil to use when I change the gear oil in a second truck I have.
3 hours ago, Ray Pickle said:
Fill to fill hole.
Is that from GM somewhere or is it the 'traditional' fill amount?
The previous generation was overfilled if 'filled to hole'.
Spec for 2500 diesel and all 3500 was 0.6 to 0.8" below the bottom of the hole.
Haven't seen a recommendation for the 2020's
The reason I was asking about the diff is that the G80 is a locker, not a limited slip.
It is standard on all 2020 3500's.
    Chris80s
    Chris80s
  • Who's Online   4 Members, 0 Anonymous, 834 Guests (See full list)
    • Still $3.01 with even more places at this price
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
