So I have a Diablo Intune with custom tune from Diablew. The engine tune is great but I’m on my 5 th trans tune and just cannot get rid of the hard 1-2 shift. Currently
only changes made to the tranny tune now are WOT shift point rpm, and shift quickness.. everything else is stock settings. I like the shift feel of the stock trans tune but hate how it hunts around when I go to accelerate while moving and there is a delay until power kicks in.
Ha Sanyo next used the stock trans tune and modified a setting to get rid of the delay
It's a pressure related issue some habe programmed out successfully, but ultimately sonnax has the resolution you seek. That entails a few upgrades. Idk maybe if you got with 1slow or someone they could hook ya up
A hard shift could also be because the engine tune isn't allowed to remove timing anymore. I've seen it where if someone changes the min timing advanced to a non negative value it won't be a smooth shift.
    250.3k
    Wasierra1500
    Wasierra1500
  • Who's Online   1 Member, 0 Anonymous, 594 Guests (See full list)
