Trying to locate a female wire connector that plugs into the body 2 connector (green) in cavity C3 in the UEC (under the hood on the wheel well, passenger side)
Nobody seems to be able to help find a part number. Any help here?
Thanks!
Did you purchase GM's fog lamp kit that would have made your whole situation plug and play and you wouldn't have to be chasing connectors?
YES, I BOUGHT KIT 84125494.  The fittings are so tight and I damaged that one, that's why i am trying to track down a part number to purchase a new one.  Got any suggestions?
People do some weird schizznitt so just making sure you were dealing with the OE lamp kit lol.
You've got two options.  Option 1 is to get another lamp kit because the harness is only part of the lamp kit.
Option 2 is the one you really probably want.  You need one of these terminated leads, p/n 19332365.  I would try to find someone that has them in stock and will sell you just one lead, otherwise its a pack of 5 if you just try to order that #.
I'd try this dealer for an online purchase:  https://www.ebay.com/itm/19332365-WIRE-General-Motors-/324102600051
Edited by newdude
Thanks for info. Checking into it now
