Has anyone, or does anyone know how to remove the 3rd brake light on the cab?  Took a look at it tonight expecting screws like in older models and don't see anything holding it on up there.  Is it simply clips? Anyone know or have a pdf?
TIA
From some searching it looks like I need To remove screws from within the cab behind the headliner to access the brake light, can anyone confirm this for me ?
Edited by 204Denali
The entire headliner gets lowered, then there are 4 bolts and 8 nuts that hold the spoiler. Once that is removed then it is 4 torx bolts to take off the third brake light. I did it last weekend. It wasn't bad.
Sent from my SM-G973U1 using Tapatalk
Awesome, thanks!
headliner is simply clips and pins holding it up I am assuming ?
Edited by 204Denali
Unfortunently no, visor has 3 torx, visor clip 1 torx, dome light 1 each side, front grab handle 2 10mm, rear grab handle 2 10mm, rear grab airbag 1 7mm (might be 8mm) back seat belt holder pops off, rear dome light clips in, this is per side
Yes, I found this out as well.  Was hoping could just drop the back end, so much for that!
    Charly
    Charly
  • Who's Online   5 Members, 0 Anonymous, 3,588 Guests (See full list)
