'03 1500 5.3 @160k vs '08 2500 6.6 @220k, both $10k. Which way to go?
I'm trying to decide between two used trucks for mostly weekend use and occasional daily driving (commute is 15 miles round trip). No towing planned. Less than 5,000 miles per year total driving. I live in the salt belt.
Candidate 1: 2003 Silverado 1500, DCSB, 5.3L 4x4. 160,000 miles, single owner, no accidents, CA truck aka zero rust. Very good service history on the Carfax.
Candidate 2: 2008 Sierra 2500, DCSB, 6.6L Duramax 4x4. 220,000 miles, single owner, no accidents, MI truck. Bed is starting to rust over the rear wheels. Extremely good service history on the Carfax, lots of parts replaced over time.
Both trucks are in the $10,000 range, which is my budget limit. I'm leaning toward the 1500 because it's rust free and probably a better fit for my needs. But the 2500 seems like a solid deal compared to other similar 2500 Duramax trucks, and the mileage doesn't scare me much after seeing the Carfax and based on what I've read about the LMM engine. I don't have a need for a 3/4 ton truck and certainly not such a strong engine, but I'm still interested in it for the deal, and because Duramax (kind of always wanted one). I'm concerned that the 2500 will be a lousy ride when unloaded or lightly loaded, which will be basically all the time for me. I'm also a little concerned about the higher running costs of the Duramax in general, but for how little miles I will put on it I'm not sure how big of an issue that is.
Not overly concerned about the generational differences from GMT800 to GMT900 ie. interiors, overall feature levels.
The 1500 is probably the logical choice, but the 2500 is tempting. What do you guys think?
A rust free 1500 all the way. I still think 10k is kinda high but I'm sure the guy is asking that because of it being a truck from CA it's whole life.
From what I could tell the truck was bought in CA, either sold or traded in, went to auction, then was bought by the current dealer in OH.
Similar age and mileage trucks are maybe $1000 cheaper but they're all viciously rusted underneath, and some through the bodywork. Clean trucks command a good price in OH, for good reason.
Yeah, short trips, no towing, I would definitely recommend against the Duramax.  They like being driven so they get hot, and can go through a full regen cycle, which your short trips won't let it complete.
I know several people that drive the 5.3 equipped 1/2 tons the have high mileage from the 2001 model up to the cylinder deactivation 5.3. I’m one of them. There’re very reliable and durable. That’s what I’d pick.
    • 286,740 Mile Services   8/6/2026   New AC Compressor. Refrigerant oil and dye, evacuate and charge system.  New exhaust system from cat back.  New Iridium plugs plus replace #3 coil Repair/rewire headlamp wiring (passenger side) and replace all forward bulbs. Polish lenses of both assemblies.  Pull rear rotors, clean and adjust parking assembly. Inspect, clean and grease front calipers. Check pads and shoes.  4 wheel power bleed of brake system. Dot 4 Reset idle speed 50 rpm higher New Serpentine belt.    Will need new pads in the rear in about 5K more miles.    Tax Title and License out the door just short of a grand.    AC clutch had bitten the dust. 1 year warranty on the pick and save replacement. Thing will make a Polar Bear cry Uncle.  He spent quite some time on the wiring. It was in the harness and he does nothing half. I got off cheap. I have considerable more light down the road. Sylvania Silver Star replacements.  Gas seal between the porcelain and shell of plug #3 was blown, cooked the coil. That was the cold miss.  Love the new exhaust. I can sneak into the neighborhood again.    This was one of her bigger bills and still way cheaper than a payment even given the oil consumption. This thing cost me under a hundred a month in repairs and normal routine costs. What is my incentive to replace it? 🤔
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
