2014 Silverado 4WD
I have a 2014 5.3 z71 Silverado. Been having problems with 4x4 I replaced 4wd actuator and transfer case motor. I continue to get a service 4wd on dash. Any help how to get this fixed really don’t know what else to do.
Welcome to this forum!  Sometimes it is worth taking your vehicle to the professionals.  Find a reputable GM service center or 4X4 specialty shop in your area and pay the extra.  It may actually end up saving you time and money!
Its got to have all the codes read in the truck.  They will shine a light on as to what part or system is causing your issue.  I'd get someone to scan it or invest in $100 and get a Blue Driver OBD scan tool.  The Blue Driver can pull codes for all modules on most GM vehicles.
Throwing parts = $$$$$$$$$
Not enough information to even start to help.  What is it doing other than showing a light?  Not engaging at all.  Engaging 4WD LO but not 4WD HI or vice versa?  Jack your truck up off the ground with all four wheels in the air.  Engage 4WD, what spins and what doesn't?  Noises?  You get my point.  Not really enough to go off of here.  Sounds like you might just want someone to take a look at it if you can't put a little more effort into diagnosing the issue.  Nothing against you or your skills.  But you have to give us more to go on here.
It engages both low and hi 4wd all four tires spin it works fine for a while until it says its turning it off on its own. That’s when the service 4wd light comes out. After it says it’s turning it off it feels as if the transfer case is still engaged but front tires don’t spin.
Feels like?  Jack up all four wheels and find out where the disconnect is and what is turning and what is not.
Old school knowledge here.  Got to just find out where it's turning and where it's not when the problem occurs.  Also could be a ground issue.  There is a main ground usually on the frame by the driver's side door to ground the system.
https://www.knowyourparts.com/technical-resources/hubs-bearings/automatic-locking-hubs/
I’ve also noticed doesn’t do it all the time but while driving it will go into gear a little hard.
    btm
    btm
  • Who's Online   6 Members, 1 Anonymous, 1,531 Guests (See full list)
    • Here's the second UOA on my 22 Wrangler with the Ecodiesel. This has 5k miles on AMSOIL Signature Series DEO 5w-40. The first one was dealer installed oil, no clue what it was, the second is what AMSOIL recommended, European FS 5w-40, Most of the Ecodiesel world is showing great results using the European MS 5w-40, I figured I would see how the DEO works. This is using an Ecoguard oil filter. It's my understanding this engine likes to shed aluminum.  We will see. So far I don't think this is too bad.
    • I'm surprised nobody seems to offer a solution like the start/stop device I put in my new truck. Remembers my setting when shutdown. And while it still starts up in start/stop, it stores/evaluates what mode it was in when shut down and will change it whithin a second or 2 of startup. It'd be nice to have something like that for the DRLs.
    • 2015 Sierra 1500 here. Leaks from the sunroof to front driver side and soaks carpet. How do I fix this? Thanks!
    • I will be doing that for sure, but I need to solve who has/ where I can find a bidirectional scan tool that will support OBD 1.5. I'm kicking myself because I ebay'ed a Snap On MT2500 that I didn't think I'd ever need anymore. D'oh!! I'd rather not buy another, so I'll contact a few local shops to see if they have one and how much they'd want to do the procedure. I'd rather have the ability to do it myself... I wish there was a modern tool that could do it all, but I'd have no idea what to buy.   The theory with the pulled timing is that it mimics a rich condition. The delayed spark causes incomplete burn and the O2 sensor picks up low oxygen levels. That's interpreted as a rich condition so the PCM pulls fuel and that shows up in the deeply negative fuel trims.
    • An ultra wealthy man had the most beautiful daughter. But, there was a problem. Everything she touched would melt in her hands. No matter what, Metal, Wood, Stone. Anything she touched would melt. She could not feed herself. Because of this, men were afraid of her. Nobody would dare marry her. Her father was despaired. What could he do to help his daughter? He consulted doctors, scientists and anybody who could solve this problem. Finally one of them said, "If your daughter touches one thing that does not melt in her hands, she will be cured." He was overjoyed and came up with a plan. The next day, he held a competition. Any man who could bring his daughter an object that would not melt in her hands would be given billions of dollars to marry her. Three extremely intelligent and handsome young men took up the challenge. The first brought a very heavy steel rod, But alas, when the she touched it, it completely melted in a matter of seconds. He sadly went away. The second brought a beautiful diamond, knowing diamonds were one of the hardest substance in the world and would not melt. But alas, once she held it in her hand, it melted. He too was sent away disappointed. So now, there was one left He was very nervous & sweating. He approached the daughter & said, “put your hand in my pants pocket and feel what is in there." She did exactly what he asked. She felt something very hard. She held it in her hand, squeezing it as hard as she could. It did not melt & remained extremely hard. Her father was overjoyed. Everybody was overjoyed. She was finally cured. Nothing never, ever melted in her hand again. They married and they both lived happily ever after, raising a wonderful family. Question: What was in the the groom’s pants pocket??? Answer below ↓ M&Ms of course! They melt in your mouth, not in your hand. What on earth were you thinking?
