Accept PayPal $300 shipped
I paid $433 Will include receipt
My location is 23430
No cutting wires - plug n play
This is a cool plug n play option to add more power to your stereo.   I hooked mine up and ran it over to the cubby hole above the glove box and fit perfectly. Was in my 17 Silverado with 8” CarPlay set up. Comes with everything you see the harness and alpine amp. It’s about 1 year old and looks and performs like brand new.
ships to lower 48
  • txab changed the title to SOLD LLJ Customs plug n play alpine amp S.I.K. GX500 set up
  • txab locked this topic
This topic is now closed to further replies.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
    • I took a 12 second video on my iphone but the file is too big to upload. I will have to figure out how to extract the audio or just do another start with an audio recording.
