Not good, was thinking about going to one, but very wary now.
Even with the issues, id get the diesel again. Its still running fine, i kinda think when it was running like crap and i had to limp it to the dealer, 2 hours, twice, may have played a part in what is happening now, which looks like it is a EGT sensor
Sent from my SM-G973U using Tapatalk
The way it seems GM is ramping up talk of electric I think I will stay with the 6.2. May be the last strong gas engine we have a chance to have new!
Heard on the news just a few days ago that the left coast is going to make sales of fossil fuel motorcars/truck/bikes illegal by 2035 for private citizens. You will be able to keep what you have but.....
Is that even possible? Do they have any idea how much of the economy is tied to the fossil fuel transportation segment in the US. IN California itself? The backlash from that segment and big oil? California is home to a major percentage of the countries refining capacity. Does GM believe they can exist on one states sales in the USA?
Just think' n out loud. Back to your regularly scheduled program. ?
Just think' n out loud. Back to your regularly scheduled program. [emoji6]
Id be suprised if that is able to happen, reguardless i dont see v8 trucks going away soon
It'll be interesting to see the electric Hummer rollout that is due to begin this month.
On 9/23/2020 at 5:53 PM, ullose272 said:
Update, engineer finally made it today, they spent most the day working on it. Ended up overnighting a engine and injector wiring harness. Hopefully have it back friday
Out of curiosity, did they extend engine warranty to the 5 years/100,000 miles with current mileage on your truck or leave it at the mileage when you bought the truck?
Left it where it was. They offered some extended warranty for goodwill. I opted for some accessorie credit.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,412 Guests (See full list)
