Just had my first issue with my truck. Was pulling my trailer for about 2 hours 2000 lbs maybe, and noticed it was cutting out a little here and there. Came to a stop, sat there idleing for maybe 5 min. Then went to go again, all of a sudden, servce ESC light, service park brake light, and service emision system light, reduced power and was cutting out really bad and really bad shudder feeling. Ideas?
Sent from my SM-G973U using Tapatalk
Sounds very similar to what happened to this guy:
He got a buyback out of it. Hope it gets addressed accurately for you, OP.
Too bad it didnt say what the issue was
13 hours ago, ullose272 said:
Truck seems to be fixed. Supposedly a connector issue, kinda makes sense
Hopefully that’s the case. Keep us posted going forward.
Its not fixed, was fine all week, pulled my small trailer to my cabin and it started doing it again. I disconnected and reconnected the ecu plugs and kind move the wiring around a little and went and drove it and it seems fine now. I think it has to do with extra load on the engine and twisting in the chassis causing it to pull on wires or short out.
There were reports of fuse blocks not being properly tightened down. Perhaps your root cause is related? Several guys with gas motors are reporting inability to restart. Seems to be electrical related.
Pulling the trailer home it stsrted doing it again, my thoughts are, when its under more load the engine is twisting causing a short or something. Seems to get worse after/while pulling a grade.
2 hours ago, ullose272 said:
Your tellin me
Dang man, I’m sorry. I’m sure it’s so disappointing to spend that kind of money and deal with these problems non stop.
    • You have to have the last word.
    • I am sure that was quite the pass experience and not a great place to experience during the winter when the conditions are not good. I've seen video of that pass and also more detailed information and pictures about the wrecks at that one hair pin turn where tractor trailers have flown right off the cliff and I am sure from all the warning signs that you know the exact curve that was !. After all there is a reason why a song was made about Wolf Creek Pass !. By the way and I didn't realize this either when I bought my truck as its nothing I even thought of that would be programmed into the cruise control and this occurs in either the basic or the more advanced cruise that controls your distance behind a vehicle and that is the brakes going down a hill are being applied as soon as the vehicle goes a certain speed over the set cruise speed. While it certainly does force downshifts in the transmission as you found out with cruise on while going down hill, its also dragging the brakes as needed to keep the speed controlled to what the cruise was set to. For me, I find that unsettling simply because I have no concept then as to how MUCH brake input is being used a and just how hot are those brakes getting and the wear factor as well. I can see that system getting a person into trouble on long mountain grades while pulling a trailer as it would not only be standing on the brakes of the pickup without any driver input, it would also be automatically applying the trailer brakes and it could cause a run away unit by overheating the brakes. Its one thing on a shorter hill and if the driver allows it to do its thing but on a long mountain grade is where things could get so out of hand. As someone a while back on this forum said, they had someone following them at night I believe on a down grade and had the cruise set and the person behind them could see the brake lights being energized all the way down the hill. I figured when I saw your comment that you didn't know and would have no way of knowing that your truck was applying the brakes and that you would and rightfully so assume you only used the brakes when you pressed on the pedal to slow down more than the cruise set speed for the slower sharp curves. So its good knowledge to know this about the newer GM trucks, certainly when doing any descending on long mountain grades. In the future try kicking off the cruise and use the the manual mode on a pass to see what that is like as I know myself when I first experienced it I thought no way can this engine be holding me back this well and tried the same hill in manual mode and sure enough the engine was revving way up and still could not hold the trucks speed down like it could in cruise mode.    Fuel mileage, that is where a really low sleek type of car can do better at higher speeds, certainly it starts sucking fuel too but a tall pickup is pushing massive amounts of air and also allowing a lot more air under it and the tow mirrors as in elephant ears pushing through the wind  as well. Driving like grandpa is about as good as one can do when driving one of these if trying to get the best fuel economy they can. I bet these trucks would get the best mileage they can if driven on a freeway in Florida if not busy traffic at a sedate speed and that sea level elevation without hills, vastly different then Colorado !.
    • It’s over for almost 24 hours. Are you playing Eddie Haskell?
