I'm confused. Black cloth console?? Are you looking for the folding jump seat in black cloth?? If not, I have one in black leather
On 4/7/2022 at 11:38 AM, denny noname said:
I'm looking for a center console, will it work for a 2020? I think it will, but not 100% sure. I have black center seat cloth, no storage, doubt you want with no storage. But willing to buy.
I am looking for the seat with storage on top and bottom.. but my console is available for you
I'm interested.  Do you have pics? How much? Not sure how to send a private message on here.
On 12/3/2021 at 4:11 AM, Michaelll said:
I have a 2020 GMC Sierra 1500 with black leather interior and a third seat. I want to trade for a center consolé because this doesn’t do any good to me.
I’m interested in trading.. where are you from?
Black leather is what I’m looking for, yes
I'd love to go to a third seat over the center console. Just means more stuff is all over the place. Lol. AFAIK it's pretty easy to swap though.
Indiana
Are you wanting to get rid of your console? If so I'm interested.
I have a 2022 Silverado with black cloth heated seats and folding center seat. There are 2 storage areas, one in the folding back and one under the lower seat. I would like to trade for a center console and leather bucket seats with seat heaters. Any takers?
I have a fold up console with the underseat storage in black, looking to swap for a full console. Lets talk!
Hey there, new to the board ... I've got a black leather folding seat with storage, looking for a center console for a 2022 Silverado. Anyone interested in swapping?
On 4/5/2022 at 6:49 PM, Bmerrill9 said:
I have a 2020 Denali console and a 2022 AT4 console available for trade and or purchase for the bench seat.. does your bench seat have the storage underneath the seat and the storage in the console  and is it leather or cloth?
do you still have this?
    • I have A 2020 1500 5.3 8 speed. LTZ. Transmission problems since 60,000 miles. Started when I go to store in morning to get my morning coffee before work leave truck running get back in put it in drive/ rev no movement step on gas a little slams into gear. Put in neutral step on gas little shake then put in gear and gose.  Shut truck off start .. ok now at stop light stop truck after a few seconds feel a little kick if that doesn’t happen stuck in 3/4 gear shut truck off wait few seconds and start usually ok again. If you down shift manually ok as long as you get into 1st before stop. If not it kicks . I WANT A NEW TRANSMISSION. Now I want a new truck it just hit 80,000 IDK IF ILL BUY CHEVY CAUSE THEY STILL HAVE THE PROBLEM AND REFUSE TO RECALL . Oh I’ve changed the fluid and filter 3 times now. And yes used mobile 1 not ac/delco cause it’s not meeting the requirements that mobile is did use ac/delco filter
    • Of course refrain from political debate but I myself have very dismal hope for what is all going on up here every where we turn so I nodded my head when I saw this joke.
    • I'm looking at carpal tunnel surgery on my left hand and lumbar fusion.
