I'm confused. Black cloth console?? Are you looking for the folding jump seat in black cloth?? If not, I have one in black leather
On 4/7/2022 at 11:38 AM, denny noname said:
I'm looking for a center console, will it work for a 2020? I think it will, but not 100% sure. I have black center seat cloth, no storage, doubt you want with no storage. But willing to buy.
I am looking for the seat with storage on top and bottom.. but my console is available for you
I'm interested.  Do you have pics? How much? Not sure how to send a private message on here.
On 12/3/2021 at 4:11 AM, Michaelll said:
I have a 2020 GMC Sierra 1500 with black leather interior and a third seat. I want to trade for a center consolé because this doesn’t do any good to me.
I’m interested in trading.. where are you from?
Black leather is what I’m looking for, yes
I'd love to go to a third seat over the center console. Just means more stuff is all over the place. Lol. AFAIK it's pretty easy to swap though.
Indiana
Are you wanting to get rid of your console? If so I'm interested.
I have a 2022 Silverado with black cloth heated seats and folding center seat. There are 2 storage areas, one in the folding back and one under the lower seat. I would like to trade for a center console and leather bucket seats with seat heaters. Any takers?
I have a fold up console with the underseat storage in black, looking to swap for a full console. Lets talk!
Hey there, new to the board ... I've got a black leather folding seat with storage, looking for a center console for a 2022 Silverado. Anyone interested in swapping?
On 4/5/2022 at 6:49 PM, Bmerrill9 said:
I have a 2020 Denali console and a 2022 AT4 console available for trade and or purchase for the bench seat.. does your bench seat have the storage underneath the seat and the storage in the console  and is it leather or cloth?
do you still have this?
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
