Just picked up a 2017 Silverado 4x4. It has a 2” lower leveling kit. The front still sits about 1/2” lower than the rear. Has anyone put 1/2” shims on top to give it the correct level or is it best to get a 2.5” leveling and take the 2” off?
    • probably won't get a response from that user, as they haven't returned to the site since making that one post.  users don't (at least I don't, and I haven't seen any setting which would notify me via say, email) get any notification other than going to this site, and checking if they got a response on their thread...
