Hi all
I need some expertise. I purchased a 2020 Silverado RST and I need to install a bed/canoe rack. I had one for my previous truck and this one will not work. I have  hard tri fold tonneau cover on the RST with its own integral frame and the old one will not fit without removing the cover. I was looking at the ADA-RACK system where the two rails mount into the stake pockets and if I get the straight uprights I can still use the tonneau cover. Does anyone have any experience with these racks and are there any mods needed to make it work??
Many thanks in advance
Cheers
Hi all
Cheers
Just installed the Adarac for the very same reason you are. Super easy install. No mods. I get compliments all the time.
Sent from my SM-G986W using Tapatalk
Thanks for the reply. just what I wanted to hear. I may have to trim some of the plastic that is formed down into the stake pocket so the metal mount doesn't try and lift of the plastic bed rail cover. Did you have to do this or did the mounts supplied work without doing this?
7 hours ago, Jaywroe said:
100٪ . Thats exactly the cover I have.
Could you post some pics when you have time ?
Thanks!
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
