Rear camera is on and plugged in, so is 7-pin.  There Is no “Towing Assistance Setup” option like the manual says. No option to enter trailer dimensions just maintenance schedule and tire pressure monitoring which now needs to be serviced and won’t take a program. This happened because I deleted all of my profiles and tried to start anew. When I choose the invisible trailer icon in the camera app it displays “calibration failed” according to the manual you activate the rear camera and start moving forward, a status bar pops up to initiate calibration, again nothing. It’s almost as if the option doesn’t exist. My truck has every option available including Pro Grade Trailering and the Technology Package. What am I doing wrong?
You do have to enter the trailer dimensions first. They are entered into the "profile" that you must create for whatever it is you are towing.invis.thumb.jpg.cdefccb38d1ef9d0f79d75945033db52.jpg
Edited by migrabill
There is nowhere in the profile to enter dimensions that I can find, I’ve searched high and low. The only choices I have are maintenance schedule and tire pressure monitoring or when plugged in “camera preview”. I’m baffled
Edited by Shawn T
I figured it out!!!! You have to choose “conventional trailer” in the profile, it doesn’t work when you select 5th wheel! That is dumb
Invisible/transparent trailer only works with conventional trailers.  So if you select a different trailer profile, you won't get dimensions.
#iworkforGM
The only kind of trailer it works with is conventional. Doesnt work with a 5th wheel. The trailer is too long and the plug is too short - it wont ever calibrate.
It worked, I just used a "conventional trailer" profile and plugged in my dimensions as I would have a tongue pull. My display looks just like yours above, instead of seeing a tongue and propane tanks I see my front stowage compartment.  Pulled it around the neighborhood for about 3 or 4 miles and it calibrated just fine.  Also my 5th wheel is 33-1/2 feet from rooter to tooter.  I had enough cable to mount the camera, run the it under the skirting, up through the gooseneck, and out of the pin box opening.  It left me 7', just enough to plug it in and have slack to back it up while in a 110 degree turn.
  • 7 months later...
How did you calibrate it. I have read there is a limit of 31 feet. You mentioned 33 and 1/2. Did you just shorten the length in the calibration?
Just shorten to maximum length.  It won't be perfect but, it will work.  The maximum length is the inch equilivant of 10 meters.
#iworkforGM
Yeah real nice of GM to create such a great feature and limit it to a certain type of trailer. I would bet more HD trucks tow a 5th wheel than a bumper pull. I will be swapping the in bed and bumper receptacles to make the camera wire routing more protected for my 5th wheel.
The measurement for the camera is taken from the bumper of the truck to the rear wall (mounting position) of the trailer.  My 33-1/2 foot 5th wheel is ~30' from the truck bumper to the back.  You need the 50' of cable though, because it needs to go from the center of the rear wall, under the trailer body, and out of your pin box, with enough slack to plug into the bumper harness.  The invisible trailer function is almost pointless, it cannot figure out why the camera on the cab is so close to the trailer body.  It looks funky but the truck camera mirrors jive with the rear trailer camera and give you a decent field of view behind the trailer and to the sides.  GM dropped the ball big time, 5th wheels should have been the main priority on the invisible trailer function IMHO.  Also, having to mount the trailer camera tailgate high is a nuisance too.  They should have come up with a technology to adjust the elevation and allow the camera to be mounted on the top edge of the back wall.
Edited by Shawn T
I agree with with you concerning mounting the camera that low on you r fifth wheel. i am also having a hard time putting holes in the back of a new unit. I also am not sure about the invisible trailer function but I am glad to hear you were able to calibrate the camera by tricking the system. I have a 2021 and want to use the new trailer guidance and trailer length app but they require you calibrate the system. I almost decided to just mount the camera high until I read your post. So thanks for the info.
Mavito, I agree 100%, Most HD will be towing 5th wheels not bumper pulls. They really need to update the firmware to accept 5th wheel parameters and when you order the 5th wheel package, change the camera hookup location to the bed. Poor execution on GMs part for sure. I hope they read this! I will be moving my camera port to the bed and hope with a 32.5 ' long 5th wheel i have enough cable.
While I'll agree the trailer camera ports should be available in the bed, I don't think you guys understand the complexity of the transparent trailer system.  My preference would be to make the coax cables long enough where you could swap the plugs between the bumper and bed.
The transparent trailer system is pretty complex system.  It stitches together four cameras (tailgate, mirror, and trailer cam) to make one image.  It also does view biasing based off the trailer turning using the tailgate camera.  To work on fifth wheel or gooseneck, you probably are going to need to use the bed camera vs the tailgate.  This probably means the trailer camera will probably need to be mounted around the roof height of the truck.
#iworkforGM
Edited by MTU Alum
I appreciate all the dialogue.
I really thought I wouldn’t be able to use the system because the salesman lied about how long the trailer could be. I have 35 foot trailer. More than enough cable but didn’t realize the cut off was 32’11. I went back and programmed the max numbers for the trailer and it worked. Works well enough for me to see to make good judgment calls while pulling. Thx to all.
Edited by 1MOGAN
    • Can someone tell me where the video processing module is in a 2023 Silverado? I'm getting conflicting results that it's in the front passenger area or the rear passenger area behind the seat.
    • Yes I agree, its what amounts to free advertising to let people know about his UOA testing company, and not that there is anything wrong with that but certainly that is a motivator for putting out videos about the science of oil as well as other topics such as oil and air filtration etc. The interesting part I found with his last video is not only the physics behind the reason for the varying wear due to a diesels working torque range causing more bearing load and that higher viscosity oil is of benefit, it was also that the chemistry behind the GM Dexos 0W-20 and the Mobil Dexos licensed 0W-20 are far enough apart that its showing up with a difference in wear even though the two oils are matched in viscosity and in that comparison viscosity was not having the finger pointed at it.    There are a few youtubers out there or one anyway that I have watched a bit of who has gone through the pains of accessing various countries manuals for a certain engine platform and while in the US/Canada it may say use 0W-20 or what have you for some Toyota product, in some other countries it sings a very different tune for the very same engine with the typical traditional oil viscosity/ambient temperature charts to help choose which oil viscosity is correct for the conditions the vehicle will be used in and in some cases its taken an engine in a US manual that states only use 0W-20 as per warranty coverage and yet that same engine in certain other countries may have up to a 15W-40 etc oil option that meets the spec. Another words the guy who is driving through Death Valley or Phoenix and south weather at 120f is often being fed a line of bs by the US system that has forced vehicle companies to restrict the warranty to a specific low viscosity oil for anterior reasons as well as the long drain interval suggestions.    Thankfully youtube is free ( yet anyway ) for viewers to sift through information and of course comes with the good and the bad ( truth and lies ) and we can choose to turn off/not watch what a person finds is bs or just not interested in the topic.
    • No doubt... But, as someone who doesn't pay for his services, but who has provided a few views/clicks on his Youtube platform, the data around the Mobil oil testing I think does have some value including to "freeloaders" like me.   A lot of what he's doing is likely showing the OE's work in their oil selection, something that many of us had kind of assumed was true all along, a good balance of both excellent protection and efficiency.
    • Lake Speed is drumming up business for his company just by being in the spot-light so he has a vested interest in stoking the 0W-20 fire.  IMO
    • I knew when I bought my truck that it had off road hill decent or craw control or whatever they call it and rolled my eyes at that but it gets throw on with other options my truck has, I just never had a heads up if the highway speed regular cruise setting had anything to do with the brakes and that took me by surprise. If you've ever been to the top of Pikes Peak and watched those ahead of you on the way down with their brake lights on constantly, one can guess they are probably not gearing down or not enough anyway if their vehicle will allow and a good reason their is a brake check spot part way down where they use an infra red heat gun to check how hot ones brakes are front and rear.    Your right that once one gets out of the front range by Denver and I've not been on that stretch of 285 between Denver and Fairplay myself but I know its high and Fairplay at 10000 feet, Buena Vista at 8000, it drops a bit from there but then your going back up and over the 11000 pass and Durango is at 6500 . So yes your definitely right that 6500 and a lot higher is the theme of going anywhere out in that direction from Denver but hey, the down hill sections give fantastic fuel mileage !.    I don't even look at the fuel pumps for what premium costs here, since I live on a farm and up to this point get fuel delivered I am rarely in front of a fuel pump and when I am, I am often using card lock bulk fuel stations so it tells me what the price is AFTER I buy the fuel. Looking up on gas buddy and converting to US gallons but in Canadian dollars, regular on average of the prices listed was around 5.95 and premium is around 7.00 . That was one reason I did not go for the 6.2 half ton aside from its lack of carrying/towing if one was going by the rule of using premium fuel and until recently one could only buy regular farm gas if playing the few cents off game for farm dyed fuel for a "farm licensed pickup". But yes I hear you on the fuel price difference and like the diesel theme with it often being more expensive then gas it doesn't have quite the charm to it either as it once did although right now here for some reason the price of diesel has come down more so its now inline with the price of regular gas.
