FlyPacNW Posted August 25, 2020 Posted August 25, 2020 I've been shopping aux tanks for a 2019 3500 Diesel. Removability isn't really a major discussion point on the products I see, so I am curious how permanent are these installations? I am on the verge of pulling the trigger on a 2019 3500 standard box and would be interested in an aux tank, but only if I could remove it if it became necessary. I know it's not rocket surgery, but not sure how invasive these installs are. FYI this would be an AUX tank (gravity feed into trucks main tank) and NOT a transfer tank (with a nozzle and pump).
flyingfool Posted August 27, 2020 Posted August 27, 2020 (edited) i think you can just splice in behind the fill port, usually this area is made of a rubber hose connection. a t-fitting to a hose to electric pump behind the fuel cap.. pretty simple, just hit a switch to power the transfer pump Edited August 27, 2020 by flyingfool
