Picking up a 2012 5.3 LC9 6L80 WT this weekend. Only 25,000 miles.
Fluids will be checked.
Mods I am budgeting for are: suspension + tires, looking at superchips flashcal to turn off AFM, and will assess the brakes.
My question is, are there any other known weaknesses on this model run/engine/trans I should be on the lookout for?
Other than the ones you already know about, no not really.
AFM and oil burning issues on some 5.3's are common. The rest is just common failure points that come with age and mileage. Like upper ball joints, leaking shocks, door lock actuators going bad. The salt belt suffers from rear wheel well rust and under the weather stripping on the bottom of the doors.
    • 2023 GMC 3500 HD, SLE, 6.6L Gas, 4x4, 6 Spd Options:  SLE Convenience Package; Driver Alert Package 1; Spray on Bedliner; X31 Off Road Package; TRAILERING MIRRORS, HEATED POWER -ADJUSTABLE, AUTO DIMMING, WITH TURN INDICATORS WHEELHOUSE LINERS, REAR INC. REAR AXLE - 3.73 RATIO INC. GVWR, 11,350 LBS. (5148 KG) INC. FRONT AND REAR PARK ASSIST, INC. ULTRASONIC     I have been launching my new boat and noticed some things related to the parking brake.. I usually set the parking brake (habit) when on flat ground for typical driving.    When backed down on the launch ramp to launch the boat and I place gear selector into Park, the parking brake activates automatically. My second nature is to set parking brake manually and noticed I was turing the parking brake off.  The parking brake appears to be setting itself automatically.   I looked all over my owner's manual and only found references to being on an incline and manually setting parking brake, or at times parking brake will be auto engaged, but nothing specific to my situation.    When is the parking brake automatically engaged?  Under what specific circumstances?  Can the auto set parameters be changed?     I like the auto set feature.  It would be nice if always engaged when shifted into Park and released when shifted out of Park (like my wifes 2025 RAV4).   Thanks!
