My 2016 Yukon is suffering from the common transmission shudder issue as outlined in TSB 18-NA-355. My dealer states they can't get the fluid anywhere. I believe it is Mobil 1 Synthetic LV ATF HP. Amazon has it in stock. My plan is to simply buy it and bring it to them. What is the amount I would need to complete the flush? I imagine more than the stated capacity amount?
Edited by sprfrkr
Look it up on Amsoil.com.
Yes you should have more than stated capacity. Best to ask the dealer, since they are doing it
Edited by txab
That TSB is 18NA355. You use 20 quarts of HP fluid to perform the flush. Your dealer is full of ******, we go threw case after case of it and never have a problem getting it.
i just run a vinyl hose off the top trans cooler line into 5 gallon bucket. idle engine  till it starts sucking air, shut off, re fill, repeat, 3x  ran about 2.5-3 gallons thru.
Dealer is full of it.  Find another one.  They all have access to the ATF from GM via the GM oil program.
That said, if you want to provide it, 20 quarts.
Edited by newdude
I am new to this thread with a 2016 Yukon Denali.  Been great for 2 weeks since I purchased used from a local dealer.  My luck today got the check engine light on and ran code and it says P0711.  The dreaded Transmission Temp Sensor error etc...The system had a transmission flush service prior to me owning it a few thousand miles ago.  I guess I have to bring to dealer to fix.....I reset code to see if it returns.  How long am I able to drive this way?  Should I take in ASAP?
Sincerely, Lenny
2016 Yukon Denali, 58000 miles.
Why would you clear the code?Bring it back to the dealer and let them fix it.That is a common problem with the M5U, as well as harsh up shifts, harsh down shifts and delayed engagement after sitting for a few hours or overnight.As well as TCC shudder,that transmission is a nightmare. I strongly suggest an extended warranty if you plan on keeping this truck for any length of time.
Edited by mjm-1957
    DM22
    DM22
  • Who's Online   1 Member, 0 Anonymous, 3,021 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
