I didn’t know these measured idle hours. Only option I get is engine hours which is obviously total run time.
  • Thanks 1
The T1's display it now I believe....even though they recorded it on K2's just didn't display it like FERD does...GM knows "most" customers flip through the display and go wow..neat blah,blah and rarely ever go back to look?  So why even display it?  So they don't....The only one that would matter to a future,current or used buyer of the truck would want the Engine Hours so they display it.  Nobody cares except for FERD buyers and their Double Limited Platinum King Horn Ranch Extreme Edition buyer who gets that Buldge feeling in his britches when he sees the "Idle Hour Meter"....ummmm that's why I bought a FERD.....He will never glean or base any ownership decisions about vehicle with the data so it's 99% useless to avearge joe.
The ability to see engine hours and idle hours is most likely for fleet/commercial use.  Idle time is a big cost for fleets.
As someone involved in fleet management... most systems that measure idle time do so by the following (numbers may vary)  Anything under 1000rpm for X amount of  seconds or minutes starts the idle time ticking...  Again, I dont know what GM considers idle.. but it will be something like that.
So, its possible that coming to a stop sign/light will increment some idle time.
Again, this is for fleet customers where you may have 100 trucks and if each is idling and hour or two per day... that's big money!!
  • 6 months later...
Idle hours is a great addition. If I'm buying a used vehicle and it has high idle time, I'll pass. I don't make money when I have to rebuild my own engines ...
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 900 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
