Evening all ,
Just picked up my 2020 2500 Duramax W/T and I’ve gotta get rid of the stock 17’’ wheels . Looking at 18 inch with 285/65-18 . I can’t get a straight answer from anyone if this will cause transmissions or Speedo issues ? Also clearance .
53 minutes ago, Oliver15 said:
Evening all ,
Welcome to the site.
285 65 18 = 32.59 for diameter, with a 7.29 sidewall.
What size are your current 17's?
26 minutes ago, CamGTP said:
Plug you tire size information into here and you will have the answer to your question.
https://tiresize.com/calculator/
People change tire sizes all the time without doing anything to the computer.
Thanks! I was just looking at that actually. I didn’t want my tires sticking outside the body so determine offset will be next . I believe stock is 44mm
245/75-17 sir
9 minutes ago, Oliver15 said:
Thanks ! 245/75-17
You are very welcome.
245 75 17 = 31.47 diameter, with a 7.23 sidewall.
265 65 18  puts you at 31.56 diameter, and a 6.78 sidewall.
New tire will be 285/65-18 .
Now I’m establishing a good offset . I wanna bring the tires out just a tad . The stock 17s sit in a bit making the stance awful .
Dealer should be able to calibrate speedo, no idea on if the tires will rub, I am out of information.
Spoke with my dealer this morning and they can reprogram for any size that was an option from factory. So I’ll be goin gin with 20 inch wheels I believe. Thanks for all the help .
It's not just the wheel size but the tire size option.  It has to be an o.d. tire size that was an option on that vehicle and not just a 20" wheel with a big tire that wouldn't have come on that truck. You're not calibrating the wheel to speedo but overall diamater of the tire to speedo.
Yes . I’m choosing a stock tire option as well. 275/65-20
    250.3k
    Griffin Donovan
    Griffin Donovan
  • Who's Online   0 Members, 1 Anonymous, 851 Guests (See full list)
