Ok fellas, calling in the reinforcements. I have this unusual tink sound coming from what I believe is in the driver front wheel area. It only happens under extremely light throttle, pulling away from a dead stop just after the truck starts rolling.  It occasionally happens when slowing down under light braking just before coming to a stop.  It's the strangest thing as normal accelerating/braking and hard driving, it doesn't make a sound.  Looked all over this thing with nothing showing any signs.  Had it at the dealer too and of course, they couldn't recreate the noise.  I'm fairly certain it is not in the suspension, and just did front brakes hoping it was a noisy pad slapping the retainer.  So that leaves me at the driveline, axle, differential, maybe transfer case, possibly front U-joint... Everything looks good to me and the dealer who did inspect everything. Seen old posts referring to the same noise but unfortunately they never replied back. I haven't done the lower control arm bolt and cross member bolt re-torque per the TSB but I'm not thinking that is what's going on. Anyone run into this before with a resolution?
Completed the TSB today on loosening and re-torqueing the crossmember and lower control arm bolts.  Haven't driven it after so we'll see tomorrow morning what she's like... ?
  • 3 weeks later...
Well, just in case any readers come across a similar single tink noise upon soft take off's and slow downs...  I've been all over this damn thing shark fin to wheel weight and I cannot source this noise! It isn't a soft noise either, very noticeable when it does it and seems to do it more frequently when warm outside.  Current plans are to finish paying it off then light the match and burn the noise out! ?
Actually, I'm now thinking it's leaf spring related and will give it more attention at some point soon after a break from laying under the truck for the last three months!
  • 3 months later...
Dead post but in case someone else comes across a single "tink' noise right after the truck starts rolling... Might oughta check out your driveshaft.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
