I tried the search button, but couldn't find my particular issue.  I went into the vehicle settings and enabled auto memory seats.  When I drive, turn the truck off, and then open the driver's side door, my seat goes to the exit position automatically.  I thought that when I got into the truck and start it up, that it was supposed to go to my memory driving position (1).  Mine doesn't, so I have to manually push the (1) button to get to the right position.
I know, first world problems, but wasn't sure if I'm doing something wrong or if that is the way I'm supposed to do it.
Thanks in advance
You have to assign the saved seating position to one of your keyfobs in order for it to do what you’re describing. Look in your owner manual and I will tell you how. I can’t recall off the top of my head.
Sounds like the truck may have 'Seat Entry Memory' turned off.
Vehicle Personalization Settings
. To have the Seat Entry Memory movement begin when the vehicle is started,
select the Settings menu, then Vehicle, then Seating Position, and then Seat Entry Memory.
Select On or Off.
See “Seat Entry Memory” later in this section.
. To begin Seat Exit Memory movement when the vehicle is turned off and the driver door is opened, or when the vehicle is
turned off with the driver door already opened,
select the Settings menu, then Vehicle, then Seating Position, and then Seat Exit Memory.
Select On or Off.
See “Seat Exit Memory” later in this section.
Seating Position
Touch and the following may display:
. Seat Entry Memory
. Seat Exit Memory
Seat Entry Memory
This feature automatically recalls the previously stored 1 or 2 button positions when the ignition is changed from off to on or ACC/
ACCESSORY. See Memory Seats
0 59.
Touch Off or On.
Seat Exit Memory
This feature automatically recalls the previously stored exit button positions when the ignition is changed from on or ACC/ ACCESSORY to off if the driver door is open or opened. See
Memory Seats 0 59.
Touch Off or On.
Thanks, that's what I did in the vehicle settings, followed from the owner's manual.  I have both seat entry and exit turn on.  I'm going to go try and clear the current settings and start over.
Figured it out.  The key fob the dealer had marked as number 1 was actually number 2.  Good times!
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed. Why not updates as well, especially since some of those can be safety related also?
    • That's good to know, but I don't think I'll even be running them under 45 in the rear  unless it's on the sand or something but will only be for a short distance anyways!    I didn't read all the instructions in the booklet yet, but do you know let's say I set the rear psi on the placard to 45, will the warning light come on soon as it drops under 45 or is there a percentage it has to drop from the set value before the warning light is triggered?
    • That's bad.  Like, its probably destroying the stub axle the CV slides into.   Do you have a proper lift installed with differential lowering brackets?  Did you install AT4/Trail Boss factory CV axles?
    • Hot? New Jersey? Today? I was working on my old 2000 Silverado 1500 today. Believe me, it was boiling hot today. As it has been.
