AT4 owners, are all the headliners black?  Stupid question, I know.  I saw a carbon pro AT4 and it looked black.  I didn’t know if this is the care for all AT4s or just the carbon pro.  Thanks in advance.
Edited by belmontfire112
I just got mine and it’s a lower end package (still loaded) it has a black headliner. I have two buddies that have packages above mine, neither is Carbon Pro, and they’re headliners are black as well. All three of our truck are black and have black leather though. I think black interior is the only option.
Edited by thomas graham
Yeah they’re all black. Would be nice if they would do the grey headliner like in the other trims with black leather. To me if you don’t have a sunroof it makes it feel a bit clostrophibic with everything being dark.
That being said, the one plus is it won’t show stains!
Yep black. Actually one of the reasons I went AT4. Have always hated the neutral headliner.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 1 Anonymous, 743 Guests (See full list)
