I have a 2020 Yukon that stalled in a drive thru. Ever since then I seem to notice that at idle it seems to have an intermittent heartbeat vibration while stopped but in drive gear. I can’t figure out if it was there before and I’m just now paranoid about it stalling or if it’s not right. I took it to the dealership and they reprogrammed the engine control module.. but it still does it. I only feel it if it idles below the third line (see photo). Has anyone else experienced this? Is it normal?
Edited by Meshe12
Correction
    • Follows the motif on the Sierra EV.  Satin finsh to the lower bumper area, painted above:   Elevation       Denali
    • Not exactly what I was hoping for, but I do like it. I wonder if they'll bring back Smokey Quartz Metallic? 🤔 https://gmauthority.com/blog/2026/06/here-is-the-all-new-2027-gmc-sierra-1500/
