1 hour ago, 14burrito said:
Thank you for the follow-up!
What's your end game here? General knowledge? Solving a problem? Planning a modification? Other?
Interestingly enough, a little bit of everything you mentioned.
This is our first GM. IMPO the cooling "strategy" has room for improvement. Based off peoples comments so far, going along with what I am seeing...I find the OE strategy (SW tuning and HW) to be lacking (my comparison is based off other vehicles, so take that FWIW).  Came here to research other peoples experience and what they were seeing. Also, see what people have been doing to remedy the "warn running" condition (plenty of info out there on that topic, so wanted this thread to be more specific and not a discussion of that). Seemingly the main go-to is a t-stat and HPTuners cooling fan tuning adjustments. The aux cooler, aside from the trans, seems to be on the back burner as I only found one person who has the Mishimoto one installed and they never responded to my DM.
Do you happen to know where I can find more details on the Dex-cool?
Going back to its history and not having a great record under high heat / load conditions - I do not see, personally, that there is any special Dex-cool formulation for the L83. Seemingly its the same stuff every other GM uses. The previous 3 GMs I have driven in the past couple months, all small SUVs, never reached ECT temps above like 190F. What is happening to the coolant/structure under thermal cycles in the L83?
Okay we're fishing.
Here's what I can tell you about Dex-Cool. I've been using it in everything GM for about 20 years without a single issue. Most issues came from users mixing it with something else. There were some issues with head gasket material incompatibility in motors that were for other reasons overheated exposing some material it didn't get along with.  VERY ancient news. Change it when your suppose to change it and you will never have an issue with it.
38 minutes ago, Grumpy Bear said:
Okay we're fishing.
Isn't research fishing until you find answers? :)
Thank you for the input, personal experience and info.
Real simple. Change all the fluids. More often is better. Changing the fluids according to the severe duty schedule has worked well for me for over 50 years.
  • Thanks 1
What's your coolant exchange schedule?
Since you decided to chime in, what's your experience with coolant temps? :)
There was a thread about coolant temps on gauge cluster here in about 2015. seems like someone reported with his mechanical gauge 210 on truck was really 198- 200 ran on aftermarket mechanical gauge.
My owners manual says service coolant at 150 K miles. At a minimum I would do 75 K miles. I did mine at about 60 K miles.
Whatever the manual miles for all services I cut the miles in half at least. Did my spark plugs at about 60 K miles not the manual 97500 miles.
As far as temps I don't worry about it because I do fluid changes.
I clean the radiator, A/C condenser and oil cooler when I do the coolant service.
Edited by diyer2
  • Thanks 1
Well, appreciate your input on maintenance schedules.
As per my OP, and posts thereafter suggest, I am looking for numbers in this thread. Real world values from people including their conditions. Was hoping you actually had some data to provide aside from, I dont worry about it because I change fluids more frequently.
Over thinking it IMO. Not worth my time.
Seemingly it was, because you added to thread...otherwise, if it really wasn't, you wouldn't have. ?
  • Haha 1
Gotta tell ya 14burrito, your poking at the wrong guy. diyeer2 gives solid input. Might not be what you want to hear but more often than not what you need to hear. Your better off with his advice than without. IMHO of course.
My response was a little facetious and I included the emoji to try and help that come across not as rude, but rather - something sparked interest enough for him to make a comment. Did not ever say that I did not appreciate what diyeer2 stated, but the thread was created asking for #s. He did indeed chime in, provided some personal feedback (which was noted and appreciated) but did not really provide what was being asked for in this discussion.
Not trying to make any internet foes by any means. Genuinely reaching out and trying to stir some back and forth discussion as I (again, personally opinion) feel that the cooling strategy seems off, odd or otherwise.
Goes back to what a wise person stated earlier in this thread:
"OEM's have their reasons. The EPA have theirs. I have mine. We don't all agree."
Edited by 14burrito
I know your mama told you once or twice that you don't have to voice every thought in your head.
DISNEY
"Thumper! What did your daddy tell you?"
"If ya can't say nothing nice don't say nothing at all."
Looking down kicking at the dirt.
:crackup:
Hey, but I'm no ones moral compass, right? You have a PM.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
