just trying to make the truck ride a little nicer. I just bought brand new tires for these 20" wheels, wish I went to a 17-18. Either way truck has 5100s all the way around, feel like the rear is a bouncy mess which is also probably because it is a single cab short bed. Whats the next step up in terms of rear shock
I have 6112s set on their highest setting up front and 5160s in the rear and it the truck rides better than stock - I have a Max tow and standard bed so not sure how that compares with your truck. I also have E load range K02s usually at 65psi and the ride is still fine.
eibach just came out with their stage two coilovers for $849. I have a set of waiting to go on so no review yet. I did however swap my rear ranchos for 5160s and it made a very noticeable difference even with the stock ranchos up front.
    contrabombarde
    contrabombarde
  • Who's Online   2 Members, 0 Anonymous, 1,389 Guests (See full list)
    • Still looks like a rivet to me in the pics, I don't see a nut and none of the pics show the head of the screw. But if you says so.....
