Because they call them air deflectors, not mud flaps. They are supposed to help reduce drag of the air hitting the tires.
But I added flaps to my rear because I was sick of scraping snow out of my bumper, otherwise I get huge puddles of slush in the garage. What a difference decent flaps make in snow country.
Plus they will keep the dirt out of there. There is a photo in the exhaust tips thread where someone removed the step. I was shocked how much dirt was in there on a nearly new truck.
Sent from my SM-A505U using Tapatalk
Mine showed up yesterday. I will install them this weekend.
Sent from my SM-T510 using Tapatalk
Well I installed mine today. I agree that lower hinge thing is not going to work. I cut them off too. I did use the screw and nut on the bottom. There is not a place for the speed nut so I just put it on top and tightened it.
I know it's a little late for some in me posting this BUT here it is anyhow. The trucks come with the "Fronts" only installed and GM does NOT offer "Matching" rear guards!!! To get matching guards you must order them both.  Now keep in mind to install the guards that GM offers on the Accessory website, you must drill into the fenders. I found that the Weathertech No-Drill rear guards not only match must closer to the front stock ones but you don't have to drill holes of course!
The Durabed fenders are aluminum. Drilling in them is not the problem it would be with steel. Just use the provided hardware as the wrong hardware will corrode aluminum.
You are correct about dissimilar metal corrosion on the GMCs but the Chevrolets are steel not aluminum, plus the fact that on either of them you are drilling holes which I and I'm sure others have a problem drilling into a new truck!
My truck is a Chevy and has the Durabed according to the window sticker. The web site says it has high strength steel for the floor. Mild steel for the interior box sides and aluminum for the exterior box sides and the tail gate. I tested it with a magnet and they are not steel.
Interesting----My understanding that only the hood, tailgate and I believe doors were aluminum??
  • 2 years later...
On 9/28/2020 at 7:11 AM, Spyderwebb said:
That's odd, the compatibility reference indicates they will fit a 2020 Silverado LT Trail Boss Crew Cab with the 5.3... but not the 6.2
Mine is a 6.2 but I missed the compatibility cross reference and went with these because it was on the "fits these vehicles" reference chart:
2020 Chevrolet Silverado 1500 LT Trail Boss Crew Cab Pickup 4-Door 5.3L 5328CC 325Cu. In. V8 GAS OHV Naturally Aspirated
I think they simply failed to list the 6.2 version and subsequently it doesn't cross reference.
Anyway they worked for me, although I did trim off the bottom flip over pinch tab... and on the very bottom tab I drilled and used another rivet since there was not an existing screw hole as the instructions suggested.
Nice Job on the install. I just received mine. I have 1 quick question, do you have to drill in to the metal in steps 6 of install instruction?
Yes, as I recall I drilled one screw hole on the bottom, for the extended bottom fender mount, this was on the back only.  Sealed the hole with a little touch up paint for protection!
I'll take a close up picture and send it in a sec!
Edited by Spyderwebb
Here is a picture looking from the ground up directly beneath the rear mudflap.  You can see I used a black anodized or aluminum rivet to secure.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
