On a drive back over Loveland pass elevation 12000. My def gauge started acting a fool where it was announcing and ever changing def range I never dismissed it (all in the 200 some range). I went from two dot from full to two dots left in a matter of a 150 mile drive. Once I got home I topped op the tank with a 2.5 gal jug, now it shows one dot away from full! Color me confused
anyone else see it behave odd?
It's not a traditional float style sensor but multiple sensors and an algorithm. it still shouldn't do that but assuming it was in between some measurements and just a one time deal?
I only have 750 miles but mine hasn't moved from full yet. i will keep an eye on it.
The def indicator is also trying to estimate range remaining -  so 'recent' rate of usage is included in the estimate.
Similar to the 'range' estimate for fuel.
DEF usage is a percentage of fuel usage, so when fuel usage is unusually high so is def usage.
Up and down the Loveland Pass means big swings in usage.
The combo of 'level' and 'range' indicator certainly seems to be causing concern for many operators.
Be sure to read the section about the DEF gauge:
https://gm-techlink.com/?p=13143
Diesel Exhaust Fluid Consumption
May 21, 2020
The diesel engines (RPOs LWN, LM2, L5P, L5D) available on 2020 Colorado, Express, Silverado 1500, Silverado 2500HD/3500HD, Silverado 4500HD/5500HD/6500HD, Canyon, Savana, Sierra 1500, and Sierra 2500HD/3500HD models use Diesel Exhaust Fluid (DEF) (Fig. 1) in order to reduce the exhaust Oxides of Nitrogen (NOx) levels within the Selective Catalyst Reduction stage of the exhaust aftertreatment system. A series of driver prompts and warnings are initiated when the DEF level falls below a calibrated value.
F01-DEF-1.pngFig. 1
Segmented DEF Level Gauge
The current 2020 Silverado 1500 and Sierra 1500 models have a DEF level gauge on the instrument cluster that provides drivers with a representation of how much DEF is in the DEF tank up. (Fig. 2) The DEF level gauge does not operate like a typical float-style gauge that is used in a fuel tank. The Engine Control Module (ECM) monitors the DEF level and consumption rate in order to calculate an estimated range. DEF levels are detected by the DEF level sensor.
F02-DEF-2.pngFig. 2
There may be some fluctuation in the amount of DEF represented on the DEF level gauge. After filling the DEF tank, it may take a few key cycles to register the correct amount in the DEF tank. With the new segmented DEF level gauge, it is possible that after adding 5 gallons (18.9 L) of DEF that the gauge reads as a full tank after the fill event. However, if the actual level of DEF is just entering the last segment on the gauge, the gauge is likely to drop by one segment shortly after driving after the fill event. As a result, a driver could have an initial impression that the vehicle consumes an excessive amount of DEF.
Emissions Requirements
Every year, GM produces diesel engines that continue to meet aggressive federal requirements to reduce Nitrogen Oxides (NOx) in the vehicle exhaust. As DEF is required to reduce the NOx in the exhaust, DEF consumption will increase as NOx reduction requirements increase. Customer trading in an older model year diesel vehicle for a newer model year vehicle will likely see an increase in DEF usage. DEF consumption increases as the newer vehicles meet the more stringent emission requirements for that model year.
The amount of DEF consumed also is a function of how hard the engine is working, or engine load. Due to engine use, it is more representative to compare DEF consumption to the amount of fuel consumed – also a function of engine load – instead of miles traveled. In addition to engine load, other factors that affect the DEF usage rate are the humidity, temperature, and altitude where the vehicle is operating.
Under certain conditions, the ECM will increase or decrease the amount of DEF used based on learning or adaptive algorithms. In the event of a malfunction and Check Engine light, the ECM may double or even eliminate the amount of DEF that is being used. An improper amount of DEF use will continue until the vehicle is repaired and the learned value in the ECM is reset.
That makes sense, I only read the section to know approximately how much each dot meant in fluid, but not the full tech b3hind it.
thanks! Then it seems everything is going great.. loving this truck so far
  • 1 year later...
I have a 2021 Denali 1500 - at approx. 5000 miles the DEF guage showed 1 bar above empty.  I added 2.5 gal. ( box).  T he guage then read I bar above half.  Now the guage is going goofy and will read 1 bar below full and the sometimes 1 bar above half and today is stuck at 1 bar below full - dealer has never heard of this - any Ideas??
    jgaudet99
    jgaudet99
  • Who's Online   4 Members, 0 Anonymous, 532 Guests (See full list)
