I have a 2020 Silverado 1500 LT 5.3 w/ 8 speed trans with just over 9k miles. After driving the truck for a while(not sure exact amount of time) but typically half hour to an hour at least. A noise starts to happen on my driver side. The best I can describe it as a dull chirping noise or something rubbing and it varies based on speed. I'm assuming its in the brake system or hub and not the motor as the noise varies based on speed but stops completely once I'm at a dead stop, and is a lot more audible on the driver side then the passenger side. I've taken my truck in before for this issue, but was told they couldn't replicate the problem and even with the truck on the lift, everything is still so new looking that they couldn't tell anything. I have an appointment tomorrow to have it looked at. I've scheduled it so I can drive the truck a while before hand and then have the tech come with me, hoping I can get it to replicate the issue while the tech is with me.
Anyone have a similar issue or any insight to point them in the right direction?
Check the dust shield on the backside of the rotor.  It can get pushed into the rotor and cause a noise once the heat generated by use causes every thing to expand.
It’s your front diff chirping. It’s a well known issue with no fix. Several threads on this. Put it in auto to see if it goes away. If it does it’s most likely your culprit. Once it warms up the stub shaft jingles around making that chirp noise. Gm has had several revisions for their tsb on this and it still has not been successful. Also, another way to tell is if you look under your truck and see if your front diff is an SU4. If so, I could almost guarantee this is your issue.
Thanks for the info, I plan on trying to make this happen before I go into the dealership tomorrow, so I’ll test that before I actually go in.
No problem, I’ve been through with the dealership multiple times. Like you’ve stated it takes time for it to warm up. It doesn’t do it as much in the winter but warmer weather it gets louder and more frequent and doesn’t take as much time driving to start hearing. As long as you get it documented.
So I did try the auto when I got it to make the noise again today. You are right, when I put it in Auto the noise went away. I went to the dealership and had the tech come with me and he herd the noise. They looked into it and talked with GM. GM told them they need to replace my axel shaft along with a couple seals. But the parts are on back order. So they said I can come get my truck and they'll call me when they get the part.
The “fix” does not fix it. It will come back. I’ve had it repaired multiple times and had my front differential replaced. There is no fix for the su4 diff.
Well that sucks, if the truck keeps making that noise its going to irritate me. If there is no fix short of putting in a new updated diff, could you try lemon lawing the truck? I guess what are you doing about it?
I hired a lawyer and settled already. I kept the truck due to low inventory. I purposely put a muffler on so that I can’t hear it now lol. Sorry for the bad news.
Sorry if you already posted this somewhere else, but what was the settlement you and GM agreed on?
Gotcha, well at this point if its not fixable I'll deal with till the point of lemon lawing it and then probably switch to Ram. But who knows how long that will take since I live in Wisconsin and the law states the same issue has to be repaired 4 times and still not fixed or sitting unusable for 30+ days. And well, they still let you drive the truck while it makes the noise and with the parts on back order. Who know how long it will take to get it fixed 4 times.
    btm
    btm
  • Who's Online   4 Members, 0 Anonymous, 1,373 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
