what is the best way to add factory navigation ( dont want to pay for onstar } and also add apple car play  ??  better to just add an after market head unit with those options ??
this is a 2014 siverado z71 8" factory screen
thanks guys
You’ll need to get a 2.5 HMI, radio compatible with your truck. I have an HMI that will allow you to gain CarPlay after programmed. Hit me up if interested.11896e772bb041a2f6ce969ba078a094.jpg
Click here, choose we are supplying the hardware then the NAV HMI with whichever audio type you have; easy peasy.
https://www.whiteautoandmedia.com/product/2014-2015-5-c-k-platform-car-play-upgrade-retrofit-programming/
WAMS is awesome to work with. You can save $100-$200 if your source yourself. I can't stress enough how easy they are to work with. Just send them an email and they'll walk you through everything.
Sent from my SM-G973U using Tapatalk
other than keeping the stock look ... why not just go after market head unit with car play and nav ??  would also have pre-amp for future amp/speakers    just asking
    • How did all that extra get added? AI bot!
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
