I am actually impressed anyone actually knew what the hell the OP was even trying to say🤔
i just bougth a brand new sierra elevation 2020 and make my undercoating wiyh fluid film and was told not to shoot the frame with it so you guys what do you use too protectthe frame. I think the first year you put nothing.....
 Thanks!
