I'm desperate guys. I've been searching and trying and implementing and testing for 3 days and I cannot figure out why I have no spark.  Working on a 2006 chevy 2500hd, 2wd with an LQ4 and 4l80e. I have crank, fuel, compression but no spark. What I've done so far
- verified <1 ohm resistance from each coil connector ground to battery negative terminal (brown wire) with key on and off
- verified battery voltage at each coil connector (pink wire) with key on
- verified pcm is sending signal for spark using data log in hp tuners when cranking
- checked and cleaned all grounds, all 4 wire harness to engine grounds, engine to battery ground, engine to firewall ground, battery to chassis ground, literally every ground I can think of and locate has been cleaned and reattached
- replaced all 8 ignition coils with known good coils from running engine
- replaced all 8 plug wires with known good wires from running engine
- replaced all 8 spark plugs with brand new ACDELCO iridium plugs
- deleted VATS
- verified good crank position signal by logging rpm while cranking in hp tuners
- checked and double checked all fluids, all full
Anybody experienced this and figured it out? Anything I have missed? I've been chasing this for 2 days now and can't figure it out. Any way to check pcm signal at coil connectors without a waveform scanner or fancy scantool?
Thanks for any input, suggestions, or help!
A friend had this problem and it ended up being a valet issue with a remote starter.
Good luck..
I am experiencing this now. Four days after we rebuilt our 6.0. Just like you ground checks, new crank and cam sensors. Hot and ground to coil plugs, no fire. Cant pull a code because it won't run. Any luck?
  • 4 months later...
- deleted VATS
I Have a 2000 gmc 5.3l no spark issue also. Got gas coming out fuel rail but no spark at plugs
Just a shot in the dark but anyway to trouble shoot anti theft?  If that is triggered it wouldn't start.  Sorry I couldn't help more.
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
    • Why do they have the gas 10l80 opening at 145?
