2018 suburban.... Passenger side running board will go halfway up then back down and stay down. Every time. Driver side works fine, I can see no obstruction, and I removed the board in case it was out of alignment. Still went halfway up and then down to stay. Any ideas?
1.  Check power source to running board.
2.  Check function of drive motor, or what ever it is, that moves the board.
3.  Find something different between working and non working board
4.  Check for an electrical resistor or some other in line electric item.
5.  Check fuzes?
Can’t think of anything else, but it has to be something that is working on one side and not on the other, or something that controls both sides and is not working correctly.
Just my 2 cents.  Good Luck.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
