My key is becoming stuck in the ignition in my 2016 Chevy Colorado while the truck is in park. The vehicle registers it is in park and the engine shuts off, but on many instances the key will not release. I've seen some other's post on this issue, but not a clear solution. Does anyone have a known corrective action for this issue? Is this an original part manufacturing non-conformance that presents after certain mileage? My truck is at ~40,000 miles.
I had this problem. 2017 Canyon about 39,000 miles.
The park sensor is not signaling park. Hence the key is stuck.
There is a service bulletin on it.
I would start the truck, move it and inch and re-park it.
I wondered if the leather around the shifter was the issue, mine worked it’s way down.
I’ve heard clean your key...etc
If you put the truck in neutral, shut it off and tried to remove the key it would not go.
I should warn you, my wife drove it to work gave up trying to get it out.. so just left it I. The lot, key in. Took the key fob and locked the doors. 4 hours later Onstar gave me a low battery warning and suggested starting the truck. Remote start would not work as the computer thinks it’s no in park. If you have onstar try it. I’d imagine the key fob won’t work either. My son drove to her work and started it, and the key came out for him after he moved it a little.
Give the dealer a hard time if you take it to them.
Find the service bulletin if you can.
Shift knob.  No special policy, special coverage, etc.  Out of warranty = out of pocket unless you want to try for warranty assistance with GM.
Quote
PI1429B: Ignition Key Cannot Be Removed and/or Does Not Rotate to the Off Position - (Jun 2, 2017)
Condition/Concern
Some customers may comment that they cannot remove the ignition key and/or that the key may not fully rotate to the “off” position (Engine does shut off).
Customers may also comment that the shift lever button appears to be already depressed.
This may be caused by the transmission control lever knob assembly not being fully seated when the vehicle was assembled, causing the shifter button to not fully engage/disengage.
Recommendation/Instructions
Technicians should inspect and verify that the transmission control lever knob is fully seated and engaged and operating correctly before replacing any parts. The shifter knob button should stand out (popped out) and NOT have the appearance of being depressed or pushed in.
If the shifter assembly is properly installed and the condition still exists, refer to SI for further diagnosis. If diagnosis finds that the shifter control lever knob needs to be replaced, ONLY replace the transmission control lever knob. DO NOT replace the transmission control.
Warranty Information
For vehicles repaired under the Bumper-to-Bumper coverage (Canada Base Warranty coverage), use the following labor operation. Reference the Applicable Warranties section of Investigate Vehicle History (IVH) for coverage information.
  • 1 month later...
Nov 2020 Update -
I reached out to Chevy and they told me I had to take the truck in to a shop to diagnose the issue. I brought my truck to the closest Chevy Dealership and within an hour they reported there was a failed safety switch in the shift lock control system. This failed safety switch in the shifter assembly required a full replacement of the shifter assembly as I was told it was integral to the assembly.  The dealership had this part in stock and were able to complete the repair within another hour. Since the truck was out of warranty, this was an out of pocket expense totaling ~$600.
I informed the dealership I intended to reach out to Chevy for reimbursement, since this was an original part manufacturing defect, not operator error. I was sent back and forth between the dealership and Chevy a few times telling me I had to speak to the dealership Customer Experience Manager. The dealership said the max they were allowed to offer was $75 towards the repair with no documentation as to why. I got back in touch with Chevy requesting more details as to why only $75 was being offered. After about a two week period, I received a call stating the dealership informed Chevy that the cause of the failed sensor was "water" damage. However, this was never reported during the shop visit or at any point up to this point. Chevy informed me there was no other appeal process at this point in time.
Current action is for Chevy, not the dealership, to send a check for ~$80 towards the repair.
I will say I was pleased with everyone at the Dealership and Chevy that I spoke with on this issue. With that said, I am extremely disappointed in Chevy's customer experience regarding the nature of the failed part. Due to their response, they have lost me as a customer for future vehicle purchases and I will expressing my concern to other family members and friends.
I will be waiting for the recall to be issued for this issue, as from my research it appears others are experience similar issues.
Agree with you Adam. Park sensors should not be failing under 40k. Maybe at 400k, but the engineer should be embarrassed to have to replace the whole shifter at $600.
  • 4 weeks later...
My 2017 Colorado had this problem almost every time I tried to shut it down. I sprayed 2 shots of wd-40 into the top shift lever button and have not had the problem again.  It has not failed since I did this a month ago.
  • 8 months later...
I have the "key won't come out" problem on my 15,000 miles 2018 GMC Canyon now. It started as an intermittent problem and they ordered shifter parts 3 weeks ago. It became a hard failure 2 weeks ago. I expected the quick low battery collateral problem and left the truck at the dealer. Neither the dealer nor GMC (escalated 2 levels so far) can tell me when the part will get sent to my dealer. Unacceptable parts problem for a "down" truck. I won't be buying GMC again.
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
