What did you learn to drive in?
pacodiablo
2 door Blazer here. I had "driven" other vehicles, but not on a road. The Blazer was the first thing I took on the road.
'66 Chevy Impalas. We had two of them, nearly identical blue 2-doors with black vinyl interiors. My dad bought one and my brother bought the other while stationed in South Carolina in the Navy. We had no idea they were the same until my brother came home on leave. There was one difference in options: my brother's had A/C and because of that the antenna mast was located on the rear fender rather than the front.
A '78 Vette...a Chevette that is! :rolleyes::sigh:
Anybody remember those? What a chick magnet that was for a highschool kid!! :cool:
I remember a neighbor in 1980 bought a new Chevette diesel. Looks & speed - not.
89 Ford F250 4x4 (dad's last "GOOD" Ford)
I then bought my 78 Monte Carlo and drove that when I was close to taking my license.
I learned with my dad's 1950 Buick, the one with the big chrome rails in front of the radiator and in-cab adjustable antenna that was located in the roof's center.
Big old beast (wish I had it). Had a standard transmission and I spent days learning how to work that thing.
Here's a URL of a similar one: http://www.dealsonwheels.com/database/cars...rs/68082big.jpg
I learned to drive in my uncle's '56 Chevy "210" - 2 door coupe. It had a 3-speed manual transmission with the shift on the column. Six cylinder too. Not a bad looking car - two tone paint - light green and white. :rolleyes:
uuhhh, early parking lot stuff in a 90 Grand Prix, first road drive in my truck, first manual in the BMW. kinda cool we still have the truck and Bimmer
Mom's 85 Celebrity wagon...moss or pea green(ugly pos, but it was purchased used for a college transport for my brother's crap...replaced a BIG red 77 Malibu wagon- had the 350 I believe...would've been fun to drive) and dad's 88 Cutlass Ciera...midnight blue with a v6...that car was perfect. The seats felt as good when he got rid of it in 96 as they did the first time I rode in it. He got it in January of 89 as it was the last 88 on the lot and fortunately happened to have the 6 vs. the 4...his 86 Century had a 4 and that was a dog on roadtrips...Memories :rolleyes:
I learned on a 1974 Chevy Bel Air Station Wagon with the 350. It was mom's car and she didn't work so it barely had 60K on it when it was 8 years old. Rust is another story. The spare tire would fall out if kept in it's stock location and if you lifted up on the 'floor mat' in the back row, you could watch the street go by under your feet.
Brings back memories of how we used to get rid of empties... We used to drop them out of the spare tire compartment (the bombay). Why the cops never pulled over a station wagon with 8 or 10 teenagers in it and beer cans coming from underneath the car, I'll never know. :rolleyes:
    • If everything checks out at the MAF, then the MAF is BAD, new or not.   You don't need a signal generator to troubleshoot this. PCM needs ALL powers and ALL grounds able to light a halogen headlight bulb - if it can light the bulb bright, then the wiring is good enough to run the PCM.   Best thing you can do for yourself is spend some time here: scannerdanner.com - Check out all his YouTube videos on similar issues. If you decide to subscribe it's the best bang-for-buck ratio in the automotive world, hands-down. He's got TONS of free vids on YouTube, too.
    • Yes, I used my multimeter to probe all of the wires at the MAF, both with the sensor connected, sensor disconnected, key on engine off, key on engine running, etc etc etc. I probed all of the wires again at the PCM, at the connectors, etc. All voltages are what they should be according to the service manual/wiring diagrams. All grounds are good, less than 20 millivolts from the battery negative under load. Both at the connector of the MAF, at the PCM connector etc.      I know this throws a pretty big wrench into things, but this truck was acting up before the swap. I don't have very much information, if any on what was causing it, but if you cleared all of the dtcs it would do the same thing where it would crank, fire, then die. And it would do the same thing a dozen or so times, and eventually it would start and run, but the difference is that it would run and actually be drivable. Whereas now if you can drive it at all, it goes into reduced power mode almost immediately, and even then it's not running correctly. When you come to a stop at a light it stumbles down to for 500 RPM before catching itself and returning to the smooth idle. And if you go more than about 50% throttle then it immediately goes back to doing the misfire thing.    Like I said, I know that throws a wrench into things, and unfortunately I was not able to pull any data or anything like that before I did this work, so I don't have much to go on.    I'm trying to not fixate on one particular thing as the cause of the problem, but it seems like all avenues are pointing me towards the PCM. Like I said I have tested the wiring extensively (see above), and during cranking the sensor does produce seemingly legitimate values at least according to my multimeter, but as soon as the engine fires those values quickly descend into gibberish. I've tried it with multiple different known working sensors, I have done literally every test I can think of multiple times on the wiring (probing the signals, probing the pins with the sensors unplugged, probing the pins at the PCM, voltage drop, voltage drop under load, continuity, ohms, and double-checking everything against the wiring diagrams/ proper values in the service data.)    Another thing that pushes me towards a possible PCM failure is, I have noticed in troubleshooting a little bit taking a break and coming back, that when I leave the truck to sit for a while and cool off, it starts and runs smoothly when I first start it up. However once it warms up. It starts having problems. For example, when I went out to the truck this morning after it had been sitting overnight, I was actually able to drive it down the block. And then once I got on the throttle a Little bit after going about a thousand ft, it started misfiring again. I pulled it back into the driveway, shut it down, and started it back up. It idled smoothly. As soon as I touched the throttle it did the misfire thing again. From then on as soon as I started it it would misfire. I shut the truck off and went to go get a coffee and do a bit more research. When I came back out I started the truck up and it immediately went into the smooth idle. After a couple of minutes of playing around with it, it would not idle smoothly anymore. Let it sit a couple of hours, rinse and repeat. This makes me think with temperature change something is going wrong inside the PCM. I have the PCM out of the 2007 donor vehicle and I'm thinking of getting a one-day subscription to the ACDelco programming service to try and program that and see if it helps.   Like I said, I'm really trying to not fixate myself on one potential cause, but it seems everything is pointing me towards PCM failure. I would really like to try to confirm that, but unfortunately I don't have an oscilloscope or a signal generator to do the GM service procedure where you feed 5 khz into the signal pin.
    • Ahh, sorry about that - I got some bad info. Newdude is correct. That's what I get for working 13 hours straight ... on my "vacation", lol.   Should've checked the files I had instead of the internet.   Anyway ... this is GREAT news, since this would've been an absolute friggin nightmare to get working.   I don't think the lack of VVT is causing this - you've got another issue. Wiring, I'm betting.   I'm telling you right now, your computer isn't bad. If it worked before the swap, it's working now. You need to do some more (better) diagnostics and figure out exactly what you're missing. Did you test every wire directly at the MAF? Have 5V reference? Ground? If you're reading ZERO g/s, your Hz isn't much use - it's going to be the wrong value anyway. The MAF is not working, and you need to find out WHY.   I got this off the net, so VERIFY first: Pin A: Black (BLK) wire, Circuit 552, serves as the Sensor Return (Ground).  Pin B: Tan (TAN) wire, Circuit 472, carries the Intake Air Temperature (IAT) signal.  Pin C: Yellow (YEL) wire, Circuit 492, is the primary MAF Sensor Signal output to the PCM. Pin D: Pink (PNK) wire, Circuit 339 or 539, provides Ignition 1 Voltage (Power).  Pin E: Tan/Black wire, Circuit 552 or similar, often associated with the Intake Air Temperature ground or signal return.  Global-A list: https://postimg.cc/KKJnQC85
    • Correct....the end user can't reach to Realtruck directly like they can if they purchase a Bak, Undercover, etc...  It has to go through a dealer.
