https://1drv.ms/v/s!AmYQt7aSeipHga0PNMkpOVA8l3am7Q
I'm in need of some help on where to start here. Also, I have no idea how to resize the video clip so I shared a one drive link to it.
But here is the issue I'm having - if you watch the very short video of the data log I did you can watch the spark jump up to insane levels. No knock appears to be detected. No codes. When the spark jumps like that the entire truck shakes almost like a misfire. It doesn't do this all the time and I can't make it duplicate the issue. It honestly does it when and how often it feels like. Sometimes the truck will run beautifully and other times it runs like it's limping along because of this.
The truck -'
2015 1500 5.3
Tuned by black bear (waiting to hear from them on this just trying to get ahead)
Cat back 3 inch straight pipe
Drop in k & n filter.
Thoughts on what the hell this could be?
