cmysstailights Posted November 1, 2020 Posted November 1, 2020 Who runs this setup Sent from my SM-G960U using Tapatalk
corn18 Posted November 2, 2020 Posted November 2, 2020 I do. On my 2500HD gasser regular bed. 11,000 lbs 5er. I have the coupler set up to move the trailer forward. This helps the ride a bit. I can still do 90 deg turns. Sure is nice to have a 35 lbs hitch I can hang on the wall when I don't need it. 1
cmysstailights Posted November 2, 2020 Author Posted November 2, 2020 Sweet, can u post pics. Im going sat to get the new camper. First time with a 5th wheel. 14k lbs. How did the gas do at 11k lbs?Sent from my SM-G960U using Tapatalk
corn18 Posted November 2, 2020 Posted November 2, 2020 I'll snap some pics later today. My 2500HD 6.0 gas does fine with 11k. It likes to spend time at 4,000 rpm and gets about 7.2 mpg. The 6.0 is bullet proof so I think it will hold up fine. What truck do you have? My 2500 has 2,738 lbs payload and with the 5er hooked up and loaded for camping, I am at 9,500 lbs on the truck. 900 below RAWR so not too concerned. But a 14k 5er would overload my truck. I put in a Curt hide a ball gooseneck hitch. Fairly easy to install and works great. The B&W is a good option as well. I also run Firestone airbags with the remote. I run about 35 psi in them when towing. I also put drop shackles on my rear leafs to level the truck when not pulling. If I didn't have the drop shackles, the truck would squat to level with the 5er. So that's why I added airbags.
cmysstailights Posted November 2, 2020 Author Posted November 2, 2020 I have a 15 high country 6.0. Payload is 2700. Did air bags, vitesse throttle controller, black bear tune and k&n cold air kit. Towing my trqvel trailer i would get 6.5 on dic running e85 with a golf cart in the bed. Sent from my SM-G960U using Tapatalk 1
corn18 Posted November 3, 2020 Posted November 3, 2020 You're going to be overweight pulling a 14k 5er.
cmysstailights Posted November 3, 2020 Author Posted November 3, 2020 I know its twice a yearSent from my SM-G960U using Tapatalk
cmysstailights Posted November 3, 2020 Author Posted November 3, 2020 Payload will be maxed but not by much and gross carrying weight will be over around 300lbs. Sent from my SM-G960U using Tapatalk
ewbldavis Posted November 10, 2020 Posted November 10, 2020 Ha...late to party on this one since you already have it. Love the Andersen. Seriously considering a Reese Goosebox though - then there's nothing to do with truck except turn the ball over. I assume they installed B&W turnover on your truck (unless already equipped)?
ewbldavis Posted November 10, 2020 Posted November 10, 2020 On 11/2/2020 at 12:34 PM, cmysstailights said: I have a 15 high country 6.0. Payload is 2700. Did air bags, vitesse throttle controller, black bear tune and k&n cold air kit. Towing my trqvel trailer i would get 6.5 on dic running e85 with a golf cart in the bed. Sent from my SM-G960U using Tapatalk Nice. Seen this a handful of times. I've seen a few that simply remove tailgate so they don't have to strap it (tailgate) up. 1
cmysstailights Posted November 10, 2020 Author Posted November 10, 2020 Ha...late to party on this one since you already have it. Love the Andersen. Seriously considering a Reese Goosebox though - then there's nothing to do with truck except turn the ball over. I assume they installed B&W turnover on your truck (unless already equipped)?I installed it. Did first pull home 300 miles. No issuesSent from my SM-G960U using Tapatalk
