Is anyone running this size tire on the factory wheels? If so did you have to run the torsion keys up at all? Was there any rubbing? I would like the little taller size up no real need for the 12.5 wide and from what I read most of the rubbing issues come from the width not the height. Thanks.
I've got 295/65/20 ridge grapplers going on my stock wheels as we speak but I also added a suspension max leveling kit. Will post pictures when I pick it up. The 295/65 is like a 35.1x11.7
  • Thanks 1
I went 37x12.50's on my stock wheels but could have gone 37x11.50's. I just thought I may end up going with a wider wheel one day. The stock tires are pretty much 34's... I wanted a bigger difference than only going to a 35
Edited by gSwift
  • 1 month later...
14 hours ago, cooldude960 said:
But you did add spacers to get those to fit without rubbing the UCA right?
I did, yes, but that was only on the Cognito control arms. To my knowledge they didn't rub the factory control arms, but I did just drive it from the tire shop to the lift shop, so I never looked to see how close they were to rubbing the OEM control arms.
    contrabombarde
    contrabombarde
  • Who's Online   3 Members, 0 Anonymous, 1,276 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
