I noticed I had the heated rear seat connector behind my drivers side rear seat.  Recently I put an oem wireless charger in my truck and in that process I bought a wiring harness for my center console that supports heated rears seats.
I have a RST Silverado 2020 with a center console.
I needed 8 parts to get hardware in place for heated seats
trim plate 84505576 $30
seat heat switch 84476688 $30
heat switch bracket 84172412 $8
harness 84482759 $56
(2) seat cushion heater 84369788 $20ea
module 13523031 $35
module bracket 84180630 $10
seat harness 84441561 $35
Total $250
I switched everything out and I tucked the heating pads under the seat covers.
I figured it was likely I would need some custom programming but I gave it a shot anyhow.
After all that it did not work. No light turns on the switch.
I thought about making a canny device but then WAMS came out with custom BCM programming for T1.  His website says support is pending for adding heated rear seats.   I have everything in place for cooled/heated front seats too but I am waiting to see if WAMS adds the heated rear seats.  Anyone done this? Or made any canny device for any functions on these trucks?
I already have the heated rears, but would love to find a way to add cooled rears as well. I mean it only sucks for the kids, but living in FL, they would be useful 9 months out of the year.
I knew the Ram had them, but no way was that enough to get me to switch ??
I've never added OEM heated seats before, especially in newer vehicles that need the BCM programmed for everything.
If anyone is looking to do it easy and fairly inexpensive, after market kits are very straight forward.
  • 5 months later...
White automotive and media services WAMS now offers this activation with autosync.  Works just like it does from factory $250 dollar upgrade if you already have autosync, you can use the new console harness from this upgrade to hook up an OEM wireless charger for another ~$120.
  • 8 months later...
  • 6 months later...
Hi Jarett - Did you ever get the rear heated seats working with the parts ?   Thx Chris
yes got it working perfectly like from factory just need parts listed and autosync device from WAMS
  • 2 years later...
Has anyone else figured this out?  WAMS replied to me that they don't have this capability....
I recently purchased all the parts and have everything in except the heating elements as they are delayed. Getting the console harness in was a pain and I haven’t installed the rear harness permanently. It’s currently hooked into the rear connector and I’m sitting at the dealer so they can get the software from GM then install the code. $225 for labor and whatever the charge is for the software from GM, they said under $100. Sure you can go the aftermarket route but I wanted all OEM parts and buttons. Just my OCD I guess. I’ll let you know when I get it working. Disassembling the center console and taking out the rear seat can be found on YouTube.
Edited by Whiskeyranch
Well my dealer now says they can’t program the BCM since my truck (LT Trail Boss) never came with rear heated seats. They said my BCM linked to my VIN wouldn’t be able to do it and I couldn’t swap out my BCM. I’m still wearing for WAMS to release their new custom programming service.
  • 5 months later...
    StewC
    StewC
  • Who's Online   5 Members, 0 Anonymous, 580 Guests (See full list)
