2013 GMC Sierra crew cab 4X4 with LC9 engine. I am pretty sure the previous owner had the AFM programmed out of it since it has never been in 4 cyl mode. I can't even get it to go into it. The problem I'm having is sometimes when I start it, the engine starts and sounds like it's flooding out, never smell fuel, just barely runs for 2 or 3 seconds then idles normally. Sometimes I turn the switch off and restart it, sometimes it does it again, but mostly it starts and runs fine. Other times I've been driving and stop at a light, or for other reason and it won't take off, just barely runs, but I put it in neutral or park and turn it off and restart it and it's fine. I've checked it for codes and there are none, I disconnected the TPS and cleaned the throttle body, which wasn't bad at all, compared to a lot of them I've cleaned. Reconnected the TPS and drove the truck and it seemed better but still does the same thing. This is not happening every time I drive it, maybe once a week, maybe twice, if I drive it everyday. Could the TPS cause this without throwing a code or any lights flashing or coming on. I just bought a new TPS and spark plugs, but haven't installed them yet. The truck has 156,000 miles on it. I've only had it about six months.
Edited by BarryKH
More info
Codes?  Check engine light on?  Have you hooked a fuel pressure gauge up to it?
Edited by newdude
Sounds like a vacuum leak.  Got to get a scan tool on there and check the Long Term Fuel Trims and you can spray a water bottle or ether or propane or whatever along the intake ports at the heads and watch the trims or upstream O2 sensor readings and see how they react to it.  Mine is cranky if it hasn't been fired up in a few days but quickly settles down.  It has a minor vacuum leak somewhere.
I recently cleaned the throttle body and it seemed to help my problem. It seems as if the harder I drive it, the better it runs. Maybe it just likes to be hot rodded a little. I'm 72, but still like to feel that power and listen to the exhaust rumble and the roar of the throttle. I'm not as up to date on these engines as I was with the old 327, 350, and especially the 396 I had in the red on red 1966 SS396 Chevelle.
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
