Looking for some suggestions on a multiple dead battery issue on a 2020 Sierra at4 (5.3l).
Over the past 6 months I have had roughly 6 to 7 times the battery looses its charge and will not start the truck.  The battery was checked twice and tested fine, on the 3rd time it was replaced, I didn’t bring it in the first time as I figured it was an anomaly.  Since the new battery it has not started 3x.  On the second time with no start they had already diagnosed a bad on star module that was just waiting to arrive for the dealer to replace (this was roughly 3 weeks ago).
On Monday the truck would not start (it started Sunday with no problems), I could not jump start it with another car, a jump pack, or the tow truck.  The dealer currently has the truck (they charged the battery and was able to start it). Currently there is no draw showing that would cause the battery to drain.  They are keeping it hooked up and monitoring now
I am out of warranty (yes I drive a lot for work), and just looking for anything that can help point in the right direction.  The dealer has been great in trying to resolve the issue, but we are both confused as to what could cause this issue.   Each time the battery has died it was been in the driveway at home.
Not sure if it makes a difference, but the cylinder head was replaced due to a DFM issue
Have the same issue with a 2019 Canyon V6. Thought it was from a USB cable that was plugged in. Tow truck started with battery pack three times. Just decided to be safe and replaced the battery. Just went to start it after sitting in the driveway with no USB cable for a few weeks. Stone dead, not even a click.
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
