Interesting discussion! It’s always great to see members sharing their thoughts and experiences. These conversations help others learn more and make better decisions. Getting feedback from users is valuable, just like the purpose of programs such as the Kroger Survey, where customer opinions help improve services and experiences.
PCM powers and grounds - EVERY one of them has to be good. Since PCM replacement didn't fix it, then all of these need to be good, AND the ground from the computer to the injectors needs to be checked end-to-end.
I use halogen headlight bulbs to test powers and grounds. Puts a decent load on the wiring. If they can light up that, then they'll run what they need to run.
If you can get the computer to ground and light the bulb using a short jumper, then the wire is bad to the injectors.
Also make sure a pin didn't get bent over when plugging the computer connectors back in, and that the female terminal puts enough tension on the male terminal to achieve continuity AND the ability to carry a load.
Register a new accountSign in
