Sorry if this is posted, couldn't find it.  I need to replace one HID bulb in my lowbeam headlight ('16 Tahoe LTZ).  Can I get a rec for OEM-like DS3 bulb? There are too many choices. Thanks in advance.
I have replaced my brand new Osrams with a pair of those Philips HID’s, they are great and genuine (from an authorized dealer of Philips).
Use the promo code in the website for a discount
https://www.powerbulbs.com/product/philips-xenon-whitevision-gen2-d3s-single
