2020 silverado hear wind noise on passenger side and drivers side. It's like door window is not shut right. Anybody have this issue?
Heard it for a while on my 2020 Sierra passenger side, I added the factory front mud flaps and seemed like the noise went away? I figured it was the factory side steps whistling and the flaps changed the wind flow, I also swapped to a shorty antenna on the passenger side. Good luck
On my 2020 3500 LT HD I had the same issue and through trial and error noticed it was 100% caused by having the air recirculation turned on. As soon as I turn it off the whistling stops. I mentioned it to my dealer during my first oil change and the said they have never heard of this before.
The road and wind noise on my T1 is noticeably louder than my K2 ever was, and my K2 had the loud Duratrac tires. But it's a much better truck in all other way.
Edited by BluegrassMotorsport
I have the rst model and the tires that came with it are the thin ones
Are yours the Goodyears? My buddy has an RST that came with Bridgestones instead and it's noticeably quieter. Goodyear has been in the business as long as anyone else and still can't figure out how to build a quiet tire.
    smandy
    smandy
  • Who's Online   2 Members, 0 Anonymous, 536 Guests (See full list)
    • from another thread   Update...although the truck sometimes seems to idle weird and the transmission shift a little weird, I've driven about 7,000  miles and no issues.   However, the way GM has handled my rental reimbursement, the situation when my truck quit, and the recall in general has led me to this point...I have driven a GM vehicle for the past 46 years and unless I buy a C3 Corvette, this is the last GM vehicle I will ever own.
