Has anyone in the Salt belt or Canada starting using a winter formula yet? If so what’s your take on using a winter formula with the best results on these BabyD’s?
Edited by Crazypontiac03
3 hours ago, Grover67 said:
I was thinking going with this one; https://dmaxstore.com/products/?route=product/product&path=2290_2493_3488_3491&product_id=415
however I like this amsoil for the pure fact of convenience one 8oz bottle covers 20 gallons.
AMSOIL Diesel All-In-One works great.  It doesn't get cold enough down here in NC but my cousin uses it in his diesel tractor on the farm in PA.  He use to have issues with fuel jelling and when he started using this all that went away.
Buddy of mine works at GM testing and recommended it. Did some other research and seems it should be good year round additive.
-Grover67
-Grover67
I’ll have to give this a shot. I’m in northern IL so January/February are usually the coldest and most miserable two months of the year around here. Truck is garaged at night but sits outside work 12-14hours a day.
Need advice.  Went to add some anti gel to my 2020 3.0L Duramax today.  Was going to give it a 10 oz shot of additive.  (Power Services Diesel Full Additive with Cetane)  Inserted the funnel about 4 inches.  When I poured the additive in the fuel filler it would not take the additive, ran out, and made a mess.  Question - is there something restricting just inside the filler ?????  Possibly I need a longer funnel ????
Thanks - J Tab
Thanks - J Tab
Lol did the same thing today! Used the wrong funnel, didn't grab the long one like the one supplied for the DEF fill that was supplied from GM.
Lesson learned.......
-Grover67
-Grover67
The one supplied is for fuel -- -according to the 3.0L diesel supplement.
(page 22)
Filling the Tank with a Portable Gas Can
If the vehicle runs out of fuel and must be filled from a portable gas can:
1. Locate the capless funnel adapter.
2. Insert and latch the funnel into the capless fuel system.
3. Remove and clean the funnel adapter and return it to the storage location.
There are 2 flappers in the fuel neck.  Pump nozzle is long enough to open both.
Not sure why the call it 'gas' in the diesel supplement -- other than it was a copy/paste from the text in the regular owners manual?
In any case the supplied adapter/funnel is for fuel, not def.
-Grover67
Yes, I used the funnel supplied with the vehicle.  The spout extends into the filler about 4 inches.  Possible it was not long enough or I did not have it inserted far enough to by-pass the flapper.
Thanks - J Tab
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 420 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
