Looking to change up to some led headlight bulbs. So far looking at the heartland leds because they list them as fitting behind the stock dust cover. Do the led headlight bulbs mess with the canbus? Am I going to need extra to combat it if they do?
Thanks
Looking to change up to some led headlight bulbs. So far looking at the heartland leds because they list them as fitting behind the stock dust cover. Do the led headlight bulbs mess with the canbus? Am I going to need extra to combat it if they do?   Thanks
 This has been covered in a few threads lol. Some might go at you for not searching, but I got ya man.
I had some LED's for a year or 2. I got fed up cause I wanted more visibility. First pic is LED's and the last two are a HID retro fit to Morimoto D2S 5.0. And sorry to answer your question the brand I had were plug and play no errors. Opt7 H11 is what I had. I should point out I have morimoto fogs too.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
